Beckman Coulter - Ac·T 5diff AL
by Beckman Coulter
Hematology Analyzer
The Ac·T 5diff AL improves sample handling by eliminating manual sample loading, which also saves time, lowers operational costs and increases your labs overall workflow efficiency. Also included is an easy-to-use data management system that streamlines data recall and requires less manual manipulation.
FORUMSView All (8)
-elab
Sat Mar 03 2018
BATH DRAIN SENSOR P/N XBA395AS
Can anyone assist me on finding this part for this instrument pls....beckman coulter act diff 5 bath drain sensorReply
-elab
Mon Jul 31 2017
ERRORmessages : how do we clear of this error,ERRORmessages : how do we clear of this error
error messages was: 1 ) Miscelaneous Message COM error on Slave 18 2 ) Miscelaneous Message MOTOR 9 is active,error messages was: 1 ) Miscelaneous Message COM error on Slave 18 2 ) Miscelaneous Message MOTOR 9 is activeReply
-imco70
Fri Aug 26 2016
error message
Hey Guys , any idea for the following error message
motor 7 is active
thanks in advance
  • Closed vial sampling that accommodates a variety of collection of tube sizes
  • Small 18 uL sample size in either closed or open vial modes
  • User-definable high/low flagging of patient results and quality control simplifies data interpretation
  • Automated quality assurance functions improve productivity
  • Closed vial sampling for controls and calibrators provides operator safety
  • Compact benchtop design requires only two square feet of counter space
  • Zero routine maintenance and high system reliability help contain costs
  • ACT 5Diff AL, checked, tested, calibrated, working condition.
  • The AcT 5 diff AL is fully automated bench - top 5 - part differential hematology analyzer with automatic loading and sampling.
  • The Ac·T 5diff AL improves sample handling by eliminating manual sample loading, which also saves time, lowers operational costs and increases your lab’s overall workflow efficiency. Also included is an easy - to - use data management system that streamlines data recall and requires less manual manipulation.
NEWSView All
Device Alert
Beckman Coulter—COULTER AC•T 5diff Hematology Analyzers: Valves May Fail Prematurely, Potentially Leading to Erroneous Results, Increased Instrument Errors, and/or Fluid Leaks See attached PDF under Manuals & Resources tab
