Leica Microsystems - RM2125 RT
Microtome
The Leica RM2125 RT version rotary microtome comes with a two-step trimming function and specimen retraction as additional features. It is designed specifically for paraffin sectioning applications in routine laboratories and provides effortless manual sectioning via a counter-balanced, exceptionally smooth-running handwheel. Offering the latest sectioning technology at an attractive price, the RM2125 RT supports uncompromising sectioning quality, ease of operation and more user safety. With a wide range of optional accessories, the instrument can be set up in virtually any configuration for both routine and special applications.
FORUMSView All (12)
2Replies3 months ago | Delrin Block Adjustment Does anyone have any tips / tricks to adjust the delrin block? I'm struggling to get even pressure across the travel. Any thoughts / suggestions would be greatly appreciated. Reply |
0Replies3 years ago | Hand-wheel not turning 360 degrees The hand-wheel of my Leica RM2125 RTS turns only 180 degrees (9-3 O'clock). It makes a clangy metallic sound at 9 and 3 O'clock and will not go any further. The tissue holder can still be advanced and retracted using the coarse wheel on the left. Have anybody had this experience? or can anyone help me out on this. This equipment is about 2 years old with minimal use .Reply |
0Replies3 years ago | Leica RM2125 RTS turns only 180 degrees The hand-wheel of my Leica RM2125 RTS turns only 180 degrees (9-3 O'clock). It makes a clangy metallic sound at 9 and 3 O'clock and will not go any further. The tissue holder can still be advanced and retracted using the coarse wheel on the left. Have anybody had this experience? or can anyone help me out on this. This equipment is about 2 years old with minimal use .Reply |
VIDEOS
- Width 400 mm
- Depth 470 mm
- Height 295 mm
- Working height (knife edge) 105 mm
- Weight (without accessories) 29 kg
- Specimen orientation (optional)
- Horizontal: 8 ° vertical: 8 ° Rotability: ± 90 °
