Need maximum capacity? Try four levels of washing!The Lancer 1600 LXP freestanding glassware washer dryer is typically found in large centralized facilities or in laboratories with large non-standard sized items. Thousands of glassware items a day presents no problem for the large 1600 LXP chamber that can wash and dry on 4 levels simultaneously. Racks are interchangeable between any of the 4 levels allowing many loading options. It is also ideal for very large vessels - 20 to 100 litres (5 - 26 gallons).
- Vast chamber (26/655cm wide x 34/855cm deep) for high volume
- Robust control system allowing for great washer functionality
- Optional independent monitoring system
- Powerful and rapid HEPA filtered drying through injectors and in wash chamber
- Increased safety with on-board storage and input of chemicals
- Higher grade 316 L Stainless Steel Chamber
All Lancer washers feature these key benefits:
- Fast cycles and outstanding results from powerful wash action and design
- Easy to use microprocessor controls with self-diagnostic software and alarms
- Flexibility of multi-level injection washing and interchangeable racks
- All sizes and types of glassware cleaned with chamber configuration choices
- Ergonomic and safe loading of racks on load bearing telescopic runners
- Choice of preset and user-customized (PIN code protected) programs
- Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps
- Robust high grade 304 L and 316L stainless steel construction (varies by model)
- IQ/OQ protocol and validation options available
- Cost effective low life cycle costs and efficient operation uses less resources and inventory
- Eco-friendly low energy, chemicals and water usage
Height | 33.66 in |
Length | 25.98 in |
Weight | 474 lbs |
Width | 25.79 in |
Feed Water Pressure 29-87 psig (200 to 600 KPa)
Heat Loss 5,950 Btu/hr (1,744 watts)
Noise Level < 69 dB
Recirculation Pump (flow rate) 198 gal/min (750 L/min)
Wash/Rinse Cycles 4 pre-programmed, 36 user-defined cycles
Water Consumption 7.9 to 9.2 gal per fill (30 L - 35 L per fill)
Flow Rate 35 L/min
Internal Depth 25.98 in
Maximum Temperature 95 °C
Power Requirement 208 V-3 Ph, 230 V-3 Ph, 480 V-3 Ph, 21 kW
