Lancer - 815 LX
by Lancer
[b]The Ultimate Space Saving Washer[/b] No need to compromise on quality of results if your laboratory has limited space or budget. The Lancer 815 LX undercounter glassware washer fits neatly in the standard 24”/60cm laboratory casework, offers professional features and the same high performance cleaning principles of all Lancer washers. Hot forced air chamber drying provides a faster turnaround in your cleaning process. Rack systems are common across the 810-1300 LX and 1800 LXA models enabling economical upgrade when expanding the capacity of your lab. The LANCER 815 LX has 2 independent wash levels with racks that are interchangeable between both levels. Racks for the 815 LX are also interchangeable between other LANCER glassware washers including the LANCER 810 LX undercounter glassware washer, the LANCER 820 LX undercounter glassware washer dryer, the LANCER 910 UP freestanding glassware washer and the LANCER 1300 UP freestanding glassware washer. Racks are sold separately.
4RepliesTue Jun 14 2011 | starting cycle 3 , system gave error 3 the system is giving the following error message : error 3 related to esseding the set Temperature could you please help us to resolve this issue thanks in advance for your cooperationReply |
[list] [*] Hot, forced air chamber drying [*] Efficient direct injection cleaning [*] Flexibility with two independent wash levels and interchangeable racks [*] Economical and accurate dosing by two peristaltic pumps [*] High grade stainless steel clad on all sides for stand alone applications All Lancer washers feature these key benefits: [*] Fast cycles and outstanding results from powerful wash action and design [*] Easy to use microprocessor controls with self-diagnostic software and alarms [*] Flexibility of multi-level injection washing and interchangeable racks [*] All sizes and types of glassware cleaned with chamber configuration choices [*] Ergonomic and safe loading of racks on load bearing telescopic runners [*] Choice of preset and user-customized (PIN code protected) programs [*] Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps [*] Robust high grade 304 L and 316L stainless steel construction (varies by model) [*] IQ/OQ protocol and validation options available [*] Cost effective – low life cycle costs and efficient operation uses less resources and inventory [*] Eco-friendly low energy, chemicals and water usage [/list]
External: 33 ¼” H x 23 ½” W x 26 ¾” D (845 x 600 x 680 mm) Internal: 20” H x 21” W x 20” D (508 x 535 x 510 mm) Effective Wash Chamber Loading Area: 421 square inches (2,716 square cm) on each of the 2 levels for a total of 842 square inches (5,432 square cm), minimum. Water Consumption: 3.1 Gallons approximately per fill. Heat Loss: 2,380 Btu/hr (697 W) maximum. Sound Level 63 dB.
