Lancer - 820LX
by Lancer
Underbench Washer with chemical storage and direct injection drying
The Lancer 820 LX underbench glassware washer dryer has the same chamber size as the 810/815 LX but is 300 mm (12”) wider externally as it has a built-in drawer for the safe storage and input of chemicals. More importantly it has powerful forced hot air drying through the injectors and in the chamber to ensure complete and rapid drying of glassware both inside and out… ready to use immediately! Rack systems are common across the 810-1300 LX and 1800 LXA models enabling economical upgrade when expanding the capacity of your lab.
  • Powerful and rapid drying through injectors as well as in chamber
  • Fast turnaround avoids waiting for glassware
  • Increased safety with on-board storage and input of chemicals
  • Economical and accurate dosing by two peristaltic pumps
    All Lancer washers feature these key benefits:
  • Fast cycles and outstanding results from powerful wash action and design
  • Easy to use microprocessor controls with self-diagnostic software and alarms
  • Flexibility of multi-level injection washing and interchangeable racks
  • All sizes and types of glassware cleaned with chamber configuration choices
  • Ergonomic and safe loading of racks on load bearing telescopic runners
  • Choice of preset and user-customized (PIN code protected) programs
  • Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps
  • Robust high grade 304 L and 316L stainless steel construction (varies by model)
  • IQ/OQ protocol and validation options available
  • Cost effective – low life cycle costs and efficient operation uses less resources and inventory
  • Eco-friendly low energy, chemicals and water usage
Washer height:845 mm / 33.27 in
Washer width:900 mm / 35.43 in
Washer depth:80 mm / 27.55 in
Chamber height:508 mm / 20 in
Chamber width:535 mm / 21 in
Chamber depth:510 mm / 20 in
Drying:HEPA filtered chamber and direct injection drying
Total electrical power:7 kW
Net weight:115 kg / 254 lbs
Loading Height:250 mm / 10 in
Water consumption:12 L / 3.1 gal - per fill
Heat loss:3,054 Btu/770 Kcal/h
Sound loss:<65 dBa
Steam condenser:standard
