Lancer - 910LX
by Lancer
The LANCER 910 LX freestanding glassware washer dryer has professional features including 304 L stainless steel construction, 42 microprocessor controlled programs, HEPA filtered Injector Drying System, and self-diagnostic software for monitoring all aspects of operation. It includes an insulated chamber for quiet operation. On board storage of cleaning chemicals with built in detergent and acid neutralizer peristaltic pumps provide labor free dosing of cleaning chemicals while the Triple Filter System protects the circulation pump from glass and debris.
[list] [*] Small footprint with surprisingly large capacity [*] Powerful and rapid HEPA filtered drying through injectors and in wash chamber [*] Increased safety with on-board storage and input of chemicals [*] Ergonomic door level height allows convenient loading and helps to avoid back strain [*] Higher grade 316 L Stainless Steel Chamber All Lancer washers feature these key benefits: [*] Fast cycles and outstanding results from powerful wash action and design [*] Easy to use microprocessor controls with self-diagnostic software and alarms [*] Flexibility of multi-level injection washing and interchangeable racks [*] All sizes and types of glassware cleaned with chamber configuration choices [*] Ergonomic and safe loading of racks on load bearing telescopic runners [*] Choice of preset and user-customized (PIN code protected) programs [*] Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps [*] Robust high grade 304 L and 316L stainless steel construction (varies by model) [*] IQ/OQ protocol and validation options available [*] Cost effective – low life cycle costs and efficient operation uses less resources and inventory [*] Eco-friendly low energy, chemicals and water usage [/list]
Washer height:1466 mm / 57.75 in Washer width:604 mm / 23.75 in Washer depth:736 mm / 29 in Chamber height:544 mm / 21.4 in Chamber width:535 mm / 21 in Chamber depth:510 mm / 20 in Drying:HEPA filtered chamber and direct injection drying Total electrical power:10 kw Net weight:143 kg / 315 lbs Loading Height:800 mm / 31.5 in Water consumption:13 L / 3.4 gal - per fill Heat loss:3,054 Btu/770 Kcal/h Sound level:<63 dBa
