Lancer - 1300LX
by Lancer
Large Capacity: at a reasonable cost
The 1300 LX Freestanding Glassware Washer Dryer easily copes with your high volumn throughput or mixed loads as this model can wash and dry on three levels yet still maintains a small footprint, keeping in mind space limitations in the lab. The 1300 LX offers a cost effective choice if you require larger capacity washing. The load-bearing door is at a safe-convenient height for loading glassware at the washer rather than having to carry or transport heavy, loaded racks from workbench to washer. Rack systems are common across the 810-1300 LX and 1800 LXA models enabling economical upgrade when expanding the capacity of your lab.
Large capacity and volume with three levels cleaning in a small footprint
Powerful and rapid HEPA filtered drying through injectors and in wash chamber
Increased safety with on-board storage and input of chemicals
Higher grade 316 L Stainless Steel Chamber
All Lancer washers feature these key benefits:
Fast cycles and outstanding results from powerful wash action and design
Easy to use microprocessor controls with self-diagnostic software and alarms
Flexibility of multi-level injection washing and interchangeable racks
All sizes and types of glassware cleaned with chamber configuration choices
Ergonomic and safe loading of racks on load bearing telescopic runners
Choice of preset and user-customized (PIN code protected) programs
Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps
Robust high grade 304 L and 316L stainless steel construction (varies by model)
IQ/OQ protocol and validation options available
Cost effective – low life cycle costs and efficient operation uses less resources and inventory
Eco-friendly low energy, chemicals and water usage
Dimensions:
External: 64” H x 23.75” W x 29” D
Internal: 25.35” H x 21” W x 20 ” D
Wash chamber load area:
3 Wash Levels - 423 square inches (2,728
square cm) per level, 1,269 square
inches (8,184 square cm) total 3 levels
Loading Height: 31” (787 mm)
Water Consumption: 3.6 to 4.2 gal per fill (14 L -16 L per fill)
Heat Loss: 3,000 Btu/hr (895 watts)
