Lancer - 1800LXA
by Lancer
[b]Dual Chamber Washing with Six Levels[/b] Capable of cleaning a large volume of glassware, the 1800 LXA provides increased workflow and output. You can load 6 independent racks on a choice of 8 levels as a result of its innovative design. The Lancer 1800 LXA freestanding glassware washer dryer is typically found in large centralised facilities or in laboratories with large non-standard sized items. Thousands of glassware items a day presents no problem for the 1800 LXA chamber that can wash and dry on 6 levels simultaneously. Racks are interchangeable between any of the 6 levels allowing many loading options. It is also ideal for very large vessels - 20 to 100 litres (5 - 26 gallons).
[list] [*] Maximizes usable space with sliding vertical door and chamber [*] High Volume - double sets of racks loaded side by side [*] Fast turn around - powerful injector HEPA filtered drying with twin turbines [*] Powerful and rapid HEPA filtered drying through injectors and in wash chamber [*] Visual check on progress of wash cycle enabled through glass door [*] Reduces inventory - uses same racks/baskets as 800-1300 LX models All Lancer washers feature these key benefits: [*] Fast cycles and outstanding results from powerful wash action and design [*] Easy to use microprocessor controls with self-diagnostic software and alarms [*] Flexibility of multi-level injection washing and interchangeable racks [*] All sizes and types of glassware cleaned with chamber configuration choices [*] Ergonomic and safe loading of racks on load bearing telescopic runners [*] Choice of preset and user-customized (PIN code protected) programs [*] Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps [*] Robust high grade 304 L and 316L stainless steel construction (varies by model) [*] IQ/OQ protocol and validation options available [*] Cost effective – low life cycle costs and efficient operation uses less resources and inventory [*] Eco-friendly low energy, chemicals and water usage [/list]
