Leica Biosystems - RM2245
Microtome
The RM2245 is a semi-motorized rotary microtome, designed for routine and research applications in histopathology and industrial quality assurance laboratories. Manual sectioning is enhanced by a high-precision motorized specimen feed, which results in efficient operation with maximum section quality and reproducibility. Choose between conventional, full-handwheel rotation, manual sectioning or "rocking mode", where the handwheel is turned back and forth over a short distance. The instrument has been specially designed for the experienced user who prefers manual over motorized sectioning.
5Replies6 years ago | reset service counter hi anyone know ,how we should clear service counter in RM2145 and RM2245 ? regardsReply |
1Reply8 years ago | RM2245 Does anyone have a service manual for a Leica RM2245 and RM2235. Regards Nick Reply |
- High precision specimen feeding: High precision specimen feeding via stepper motor provides consistent section quality for sensitive staining methods.
- Large 70mm vertical stroke: The large 70mm vertical stroke allows sectioning of super mega cassettes and also supports safer specimen changing due to the greater distance to the knife edge.
- Adjustable handwheel balance system: Patented adjustable handwheel balance system protects the specimen because the object head does not drop into the knife when sectioning is stopped.
- Precision orientation system: The optional 8° X/Y precision orientation system with calibrated controls helps to quickly orient already cut specimens (re-cuts). The system then rapidly returns the exact zero position, which is marked by two red indicators.
- Width (with handwheel):413 mm/16.26 inches
- Width (without handwheel):300 mm/11.81 inches
- Depth (with waste tray):618 mm/24.33 inches
- Depth (without waste tray):520 mm/20.47 inches
- Working height (knife edge):100 mm/3.94 inches-(measured from the base plate)
- Working height (knife edge):168 mm/6.61 inches-(measured from the stage)
- Height (total):305 mm (with storage area on the housing)/12.01 inches
