Lancer - 4800 TI/TIDP
by Lancer
Industrial washing for large items
The 4800 TI / 4800 TI DP high performance Industrial Washers provide effective mechanical, thermal and chemical cleaning. The 4800 TI / 4800 TI DP washer is designed to meet the growing demands of the biotechnology, agritech, petrochem, pharmaceutical, QA/QC laboratories and other industries. It's rugged design and superior construction materials (chamber, door and valves of 316 L stainless steel) help to withstand the aggressive products found in industrial applications. Advanced options including traceability of cycles, validation of cycles, chart recording and a conductivity meter for the more rigorous requirements of industrial applications are available.The4800 TI / 4800 TI DP models offer a single door(TI) and double door(TI DP) variation for pass through applications.
-lesudiste
Invalid Date
conductivité
Bonjour, voila j ai un problème lors d un cycle de rinçage ou de nettoyage matériel j ai une valeur de conductivité assez élevé pouvez vous m' éclairer svp .
merci d avance.
Translation: Hello. I have a problem during a cycle of rinsing or cleaning equipment. I . have a high enough conductivity value m can enlighten please.
  thank you in advance.
[list]  [*] Rugged design for industrial applications  [*] Main recycling pump constructed of stainless steel to withstand aggressive chemicals  [*] Chamber and door constructed of 316 L stainless steel  [*] Advanced options: traceability, validation, conductivity meter and additional dosing pumps  [*] Double door configurations for pass through applications    All Lancer washers feature these key benefits:  [*] Fast cycles and outstanding results from powerful wash action and design  [*] Easy to use microprocessor controls with self-diagnostic software and alarms  [*] Flexibility of multi-level injection washing and interchangeable racks  [*] All sizes and types of glassware cleaned with chamber configuration choices  [*] Ergonomic and safe loading of racks on load bearing telescopic runners  [*] Choice of preset and user-customized (PIN code protected) programs  [*] Accurate and repeated intake of cleaning chemicals by automatic peristaltic dosing pumps  [*] Robust high grade 304 L and 316L stainless steel construction (varies by model)  [*] IQ/OQ protocol and validation options available  [*] Cost effective – low life cycle costs and efficient operation uses less resources and inventory  [*] Eco-friendly low energy, chemicals and water usage  [/list]
