Leica Microsystems - RM2255
by Leica Microsystems
Microtome
Reduce repetitive motions that can contribute to musculoskeletal disorders with the powerful, fully automated Leica RM2255 rotary microtome. Designed for fully motorized sectioning of both paraffin- and resin-embedded specimens, the Leica RM2255 supports a broad spectrum of applications; in routine and research laboratories; in histology; in industrial materials and quality control. Its two-in-one design concept, which allows motorized and manual sectioning, provides reproducible high-quality sections.
FORUMSView All (19)
-FrankKey
Thu Jul 10 2025
Automotive cutting not functioning
Try engaging auto cut clutch gauges. Motor does not turn rear black reset button trips from time to time, but when it doesn’t auto mode does not function.
Equipment: Leica RM2255
-kpietryka
Tue Aug 27 2024
thick and thin
what part of the microtome controls thick and thin? its not blade or chuck problems. adjustment more than likely
Equipment: Leica Microsystems - RM2255
-Hasib
Tue Jun 11 2024
small motor movement
spacemen dos does not move Forword neither backorder
VIDEOS
Cutting Modes Leica RM2155...
Leica RM2155...
  • Consistent sectioning speed: Consistent sectioning speed and force of the fully-automated cutting motor supports consistent, high-quality sectioning and helps to reduce musculoskeletal disorders caused by repetitive motion.
  • Precision orientation system: The optional 8° X/Y precision orientation system with calibrated controls helps to quickly orient already cut specimens (re-cuts). The system then rapidly returns the exact zero position, which is marked by two red indicators.
  • Large 70mm vertical stroke: The large 70mm vertical stroke allows sectioning of super mega cassettes and also supports safer specimen changing due to the greater distance to the knife edge.
  • Unencumbered work area
  • Fewer clamping levers provide an unencumbered work area.
