Instruments suitable for processing
in the washer-disinfector
In general, only high quality stainless
steel items are suitable for processing
in the washer-disinfector.
All items to be cleaned and disinfected in the washer-disinfector should have the following properties - heat resistance to a temperature of 95°C/203°F and corrosion resistance in the presence of heat and alkalinity.
The heat retention capacity of stainless steel allows for fast drying. Plastic has a lower heat retention capacity, thus requiring a longer drying time. In this case, a slightly extended waiting period of 5-15 minutes may be necessary after the disinfection cycle. Aluminum items may discolour during the cleaning process. Aluminum has only a limited suitability for processing in the washer-disinfector. Carbon steel and chrome-plated items may corrode during the cleaning process. Processing these types of items in the washer-disinfector is NOT recommended. Hand pieces, drill bits, grinders, root canal instruments or other rotating items are not suitable for the washer-disinfector. Do not process them in the washer-disinfector.
Height including lid
Height without lid: 85 cm (33 7/16")
82 cm (32 5/16")
Width 60 cm (23 5/8")
Depth
Depth with door open: 60 cm (23 5/8")
120 cm (47 1/4")
Weight (net) 70 kg (154 lbs)
Voltage / Fuse see data plate
Power cord approx. 1.8 m (5' 11")
Water temperature:
Cold water
DI water connection
max. 20°C
max. 70°C
Static water pressure max. 145 psi (10 bar)
Min. flow pressure:
Cold water
DI water connection
10 - 147 psi (7 - 10 bar)
Recommended flow pressure:
Cold water
DI water connection
0 25 - 60 psi (1.72 - 4.13 bar)
Drain height min. 0.3 m (1 ft), max. 1 m (3.3 ft)
Room temperature 5°C (40°F) to 40°C (104°F)
Relative humidity:
maximum
linear decreasing to
80% for temperatures up to 31°C
50% for temperatures up to 40°C
Altitude above sea level up to 1500 m (1640 yds)
Contamination level P2 (as per IEC/EN 61010-1)
Ingress protection rating
(as per IEC 60529)
IP20 (ingress of dust)
Noise level in dB (A),
peak LpA for cleaning and drying cycles
< 70
