STERIS - Reliance 444 Series
by STERIS
Washer/Decontaminator
The Reliance 444 Single-Chamber Washer/Disinfector, a mechanical washer/disinfector, is equipped with an Eagle® 3000 Stage 3TM control system. The washer/disinfector is designed with seven factory set cycles: Instruments, Gentle, Utensils, Glassware, Plastic Goods, Anesthesia/Respiratory Goods, and Decontamination. Three additional cycles are available for customized programming to meet specific operating requirements. Each preprogrammed cycle is equipped with Pre-Wash, Wash, Rinse, and Thermal Rinse (including Drain Discharge Cool Down) phases. The washer/disinfector is built to seismic design and includes a vented system and interior chamber light. The washer/disinfector offers both manifolded and non-manifolded washing and a power vertical sliding door, in a single- or double-door configuration.
2RepliesWed Feb 28 2024 | manual looking for the manual Equipment: steris amsco 444 washer Reply |
3RepliesTue Dec 05 2017 | water in chamber Customer reports every now and then there is water in the chamber at the end of cycle. I have checked the drain valve operation and it is working properly. The water fill valves are not leaking by. I have sat and watched this unit run over and over and of course will not do it when I am onsite. I am thinking about rebuilding the drain valve and see what happens. Any other ideas out there?Reply |
4RepliesTue Dec 13 2016 | pure h20 tank failed to reach temperature i have amsco relience 444 washer, error generates (pure h20 tank failed to reach temp). can any one guide me Reply |
