STERIS - Reliance Vision Single Chamber
Introducing the Reliance Vision Single-chamber Washer/Disinfector, a total integrated washing solution from STERIS.Sterile processing departments are challenged with achieving higher productivity levels than ever before. As a result, Customers need a powerful washing and disinfection system that can process high volumes of medical devices, utensils and delicate instruments quickly, efficiently and safely. Customers also need a system that is simple to operate and maintain. Introducing the Reliance Vision Single-chamber Washer/Disinfector, a total integrated washing solution from STERIS. Featuring the newest innovations in the single-chamber market, the Reliance Vision combines the latest technology with a groundbreaking design to provide maximum throughput and unparalleled performance.
FORUMSView All (12)
0Replies3 years ago | Wet contol panel on clean side Every so often there is water dripping off the clean side control panel. I know the water is dripping from the HEPA filter assembly above the panel. The HEPA filter and prefilter is dry. The condensation system is working. I have replaced all the worn plastic pieces that might be spraying water in the direction of the vent. The blower is turning in the correct direction. There is no leaking fluid tubing over it. It doesn't do it on every cycle ran or on a specific cycle. My question is, How is the water getting in the HEPA assembly filter if air is drawn through it from the outside? All the checks mentioned above were recommended by Steris Tech Support. Reply |
1Reply3 years ago | All controls stop working Halfway through a cycle, all actions stop operating. None of the valves turned on when they were supposed to...doors wouldn't open. I went into service mode to inputs/outputs and tested the door and all the water valves and nothing would operate/energize. I checked the incoming air at the regulator and it was fine. What else should I be checking? What could cause this? Thank you. Reply |
0Replies3 years ago | STERIS - Reliance Vision Single Chamber Washer is stuck on Steris Logo screen At startup, the system goes to the desktop screen then the Steris screen with the progress bar. After the progress bar, it still just sits on the Steris screen. Can someone tell me how to access the Softlogix Controller to verify it's on "run'' mode? Thank you.Reply |
Productivity & Connectivity Faster, optimized cycles Touch screen, PC controls can interface with instrument tracking and OR scheduling Longer spray arms and outward spraying nozzles for improved coverage Large capacity for processing high volumes of medical devices, utensils and delicate instruments Improved drying system Integrated flow meters provide verification of chemistry injection rates, even down to the Prolystica® Ultra Concentrate levels Quality Easy-to-clean spray arms; simple assembly Self-flushing centrifugal filter system prevents spray arms from clogging and helps minimize maintenance PC control is remote monitoring enabled allowing proactive/predictive repair for improved system uptime Racks are capable of lumen flushing Safety Ergonomic design enhances operator safety Immediate-level disinfection phase helps reduce the risk of infection for patients and staff Cool-touch handles on racks for safe handling of racks once they exit the washer Environmentally friendly system uses less water, detergent and utilities
