STERIS - Reliance Synergy
by STERIS
The Reliance Synergy Washer/Disinfector is designed to meet increasing reprocessing needs of hospital CSSD?s and Ambulatory Surgery centers.
The Reliance Synergy Washer/Disinfector is designed to meet increasing reprocessing needs of hospital CSSD?s and Ambulatory Surgery centers worldwide through improved efficiency and reduced utility consumption. Synergy introduces new washing systems technology to address key customer concerns including:      Shorter cycle times for faster reprocessing of critical instruments and utensils. Reduced operational cost and less environmental impact by minimizing water, utility, and detergent consumption. Increased throughput capacity utilizing a validated 5 lead washing manifold capable of processing 10 instrument trays per cycle. Greater confidence in cycle outcomes through the addition of an Independent Monitoring system that double checks all critical parameters of washing, rinsing, disinfection and drying on every cycle. Improved microbiological containment through the inclusion of HEPA filtered air for drying and new airtight door design.
FORUMSView All (13)
-RBFC
Sat Feb 13 2021
Door chamber
How do you open the door chamber with no electric power.Reply
-Bob@montaquip
Fri Oct 20 2017
Service manual
I need a service manual for this unit. Anyone have a PDF they can forward? ThanksReply
2
-leonardo mahidlaon
Fri Jun 02 2017
printer not printing good
how to fix the printer for the washer decomtamination Reliance SynergyReply
Vertical sliding doors are constructed of tinted, tempered   glass with stainless-steel trim to allow the operator to view the   chamber with the doors closed. While the cycle is in progress,   glass doors remain cool to the touch. Doors are pneumatically   activated with a built-in safety system.   Sliding doors create an airtight seal and are configured for   power door operation.   • Power doors are opened and closed automatically using   touch pads located on the control panel. If a power failure   occurs, doors can be opened manually. A door interlock   feature is provided to prevent cross-contamination.   Stainless-steel pump is powered by a dual-speed motor. High   pump speed provides the equivalent capacity of a 7.5 hp   (5.6 kW) motor, 240 U.S. gal./min at 70 ft (910 L/min at 21.3 m)   head pressure. Low pump speed provides the equivalent   capacity of a 2.0 HP (1.5 kW) motor, 90 U.S. gal/min at 25 ft   (341 L/min at 7.6 m) head pressure. Pump impeller is mounted   directly on the motor shaft and does not require additional   bearings. Pump motor is equipped with a drip-proof frame,   magnetic starter, overload protection and sealed bearings (not   requiring periodic lubrication).   Pump, spray system and all recirculating piping are of stainless-   steel construction.   Single removable stainless-steel filter in the chamber sump   prevents debris from entering the pump.   Heating coil (steam or electric) at the bottom of the wash   chamber (sump) raises and maintains water temperature up   to 180°F (82°C) during the Wash phase and up to 203°F (95°C)   during the Thermal Rinse phase.   Rotary spray assemblies are positioned (one at top and one   at bottom of chamber, each measuring 24-3/8" [620 mm] long)   to reach all surfaces of the load. Every manifold used with the   Reliance Synergy Washer/Disinfector has bi-directional rotary   arms positioned on the top and bottom of each load shelf.   Depending on the type of rack accessory in the chamber, the   manifold connector automatically connects to the accessory   at the start of each cycle.   16-W fluorescent lamp, mounted within an explosion/vaporproof   enclosure, illuminates the chamber interior.   Wash chamber is constructed of 16-gauge, #304 L stainless   steel (No. 4 finish), argon-welded; wash chamber is of sanitarytype   design for complete drainability. All horizontal fixed surfaces   are sloped, overlapping metal sheets are minimized to   reduce hard-to-clean locations, and there are no dead legs of   more than six times the pipe diameter. A complete drain water   sensor detects the presence of water in the piping.   Double-walled, insulated construction of chamber exterior   reduces heat loss and noise level to the work area.   Chemical injection pumps. The system comes with one   enzyme and one detergent injection pump which automatically   add a selected quantity of chemical from 1/8 to 2.0 oz/gal (1.0   to 16 mL/L). Up to two additional chemical pumps give flexibility   to wash with a neutral process, dual alkaline/neutralizer process,   or to vary the chemical used, depending upon the load.   One injection pump is also provided to automatically add a   selected quantity of lubricant (from 0 to 2 oz/gal [0 to 16 mL/   L]) during the Thermal Rinse phase.   If desired, up to two additional chemical injection pumps can   be installed on the washer/disinfector. Optional injection   pump(s) can be ordered alone and/or with the Fast Cycles for   Instruments and Utensils option.   A low-level sensor is included to indicate when the detergent   level in the container is low, or when insufficient chemical is   available for the next cycle.
Size (W x H x L)   Exterior dimensions:   • 42 x 80 x 32-5/8" (1067 x 2032 x 829 mm)   Interior chamber dimensions:   • 24 x 26 x 24" (610 x 660 x 610 mm)   Load height:   • 31" (787 mm) above finished floor
