Diatron - Abacus 3
by Diatron
Hematology Analyzer
Abacus 3 is a heavy duty compact hematology analyzer offering an optimal solution for hospitals, clinics and practices, which require higy quality and fast CBC results.The built-in roller printer, the automatical cleaning and the multilingual operating menu makes it really easy to use.
FORUMSView All (6)
-Engine light
Wed Sep 02 2026
Looking for Diatron Abacus 380 EM Key / Hardware Reagent Lock
Hi everyone,
I am currently working on a Diatron Abacus 380 hematology analyzer. The machine has a strict software version that requires the hardware key (Dallas key / EM sign) connected to the back panel to credit the tests.
I am looking to buy a permanent EM Key Emulator (Hardware Bypass Key) or an unlimited reset chip so I can run the analyzer with alternative compatible reagents without the counter locking up.
If there are any biomedical engineers, independent service providers, or spare parts suppliers here who can program and ship this emulator key to Egypt, please contact me with the price.
I would also appreciate any advice or technical tips on how to bypass this reagent lock via the service menu if possible on newer firmware versions.
Thank you
Equipment: Diatron - Abacus 380
-Boushra
Wed Nov 14 2018
Irgent
Ined service manul Reply
-Vjanand
Sat Sep 02 2017
Need user manual to operate the machine
Hi, we have diatron abacus 3 machine and need user manaul to operate. Kindly help.Reply
  • Color LCD, the large display allows rapid and accurate patient data entry and monitoring of the results with large histogram
  • Sample rotor, ensuring safe and easy sampling
  • The instrument features a sophisticated but easy-to-use, logically constructed multilingual operating menu. It provides 6-level QC, L-J graphs and self-diagnostic functions to let you monitor reliability and accuracy
  • All Abacus models can be interfaced with your host computer for further processing of the measured data. Results can also be retrieved on the built-in roll paper printer
  • Abacus 3 provides 18-parameters, a complete CBC including a 3 part WBC differential
  • High throughput of 60 samples per hour, results within 60 seconds
  • The fluidic system is automatically cleaned from dust particles when turning on the analyzer.
  • High voltage pulses after each measuring cycle keep the apertures free from clogging. The instrument automatically cleans the sampling tip inside and outside after blood aspiration to minimize the risk of carryover and infection.
  • Abacus 3 is almost maintenance free resulting in minimal disruption of operation
  • Clinical environment by utilizing industry standard electronic and mechanic components
  • Throughput: 60 tests/hour
  • Parameters: 22 including 3-part WBC-differential – WBC, LYM, MID, GRA, LYM%, MID%, GRA%, RBC, MCV, HCT, HGB, MCH, MCHC, PLT, MPV, RDW-SD, RDW-CV, PCT,PDW-SD, PDW-CV, P-LCR, P-LCC
  • Volumetric impedance method
  • Sample volume: 100 μL
  • Sampling method: Open & closed tubes
  • Pre-dilution option
  • 3 cyanide-free reagents: Diluent, Lyse & Cleaner
  • Diatro•ECO Reagent Pack: Up to 145 measurements
  • Quality Control: 24 QC lot, Levey-Jennings graphs, USB and barcode option to load QC target values, capable to read QR codes for reference input data
  • Data storage capacity: 10,000 results
  • Optional external barcode reader
  • Built-in thermal printer module, 58 mm wide roll paper, full report with histograms
  • Color touch screen operation
  • Logical/intuitive user interface
  • User language: English, German, Bulgarian, French, Greek, Indonesian, Polish, Portuguese, Romanian, Russian, Slovakian, Spanish, Turkish, Italian
  • Size (Width x Depth x Height): 32 cm x 49 cm x 36 cm, 12” x 19” x 14”
  • Weight: 18 kg, 39 lbs
