Thermo Fisher Scientific - HM 325
Microtome
Adjust microns from left or right side for user comfort. Wing-style dovetail knife support. Removable blade carrier levers help protect settings; protective blade guard design moves blade without exposing blade edge. Zero position specimen head. Smooth turning handwheel and precision micrometer feed system. Vertical movement on maintenance-free cross roller bearings. Section thickness range from 0.5 to 60µm with a full-feed range of up to 28mm. Integrated specimen retraction on return stroke protects knife and specimen. Integrated section trimming device automatically trims block at 10 and 30m. Integrated waste tray with arm rests.
FORUMSView All (4)
4Replies2 years ago | Service manual The manual retract plastic gear is not engaging. Need detail part list for the gear. Thank you StanleyReply |
1Reply2 years ago | Knife type I am looking for a knife fitting yo this machine. Do you know a specific product?Reply |
2Replies3 years ago | Cryostat service manual Has anyone go a service manual for the Thermo HM525 cryostat? (Must have selected the wrong instrument in the description and can't figure out how to change it) Reply |
- One-handed zero orientation head
- Quick-trim button
- Section counter
- Guide-rail guidance for the knife holder
- Large, easy-to-clean waste tray extends below the blade holder
- Cutting Range 0.5 to 60µm
- Cutting Increments 0.5µm 0.5 to 2µm 1µm: 2 to 10µm 2µm: 10 to 20µm 5µm: 20 to 60µm
- Maximum Horizontal Feed Range 28mm W x D x H 161/2 x 191/4 x 11 in. (42 x 49 x 28cm)
- Weight 503/4 lb. (23kg)
