Diatron - Abacus 4
by Diatron
Hematology Analyzer
Abacus 4 is part of the high-end of Diatrons Abacus family for human use. The Abacus 4 offers an optimal solution for hospitals, clinics and practices, which require high quality 3-part WBC differential results and an accurate measurement of eosinophilic granulocytes. Our Hematology analyzers bring the convenience and accuracy of the reference laboratory right into your practice, offering maximum value at low running costs.
-sarkawt
Mon Apr 14 2014
diluent sensor not wark properli
diluent sensor does not work properly
  • 4 part WBC analysis (3 part + EO)
  • 20 parameters » WBC, LYM, MON, NEU, EOS (LYM%, MON%, NEU%, EOS)
  • RBC, MCV, MCH, MCHC HGB, HCT, RDWc/s,PLT, MPV, PDWc/s, PCT
  • 20 tests/hour
  • built-in printer
  • internal database
  • USB ports
  • RS232 port
  • results stored and displayed with histograms
  • selectable units, languages
  • integrated QC programme
  • fully automated sample-handling, measurement, clog-prevention
  • simple, cost effective operation
  • Diatron reagent system
  • Sample volume:50 µl of whole blood
  • Measured parameters:20 parameters, including 4-part
  • WBC differential: WBC, LYM, MON, NEU, EOS, LYM%, MON%, NEU%, EOS%, RBC, HCT, MCV, RDW, HGB, MCH, MCHC, PLT, PCT, MPV, PDW Reagents*:Isotonic Diluent, Lyse, Diff 4, Cleaner
  • Throughput:20-28 tests/hour
  • Sampling method: Open tube system with automatic sample rotor
  • Built-in printer:”Easy Paper Operation” thermal printer, 56 mm wide roll paper
  • User interface:Easy-to-use, menu driven user interface with 6 software buttons (with icons),6 hardware function buttons, cursor and numeric keys and colored LCD display
  • Dimensions (WxDxH):320 × 260 × 365 mm
  • Net weight:12 kg
