Diatron - Abacus 5
by Diatron
Hematology Analyzer
The Abacus 5 system is a compact, bench top, 60 test/hour, 5-part WBC differential analyzer with two sampling modes: a cap piercing mode for closed tube sampling and another for open tubes.
0Replies4 years ago | Diatron Abacus 5 Diatron Abacus 5Reply |
0Replies7 years ago | Installation Good Day, Please kindly assist me with a installation manual for the above mentioned device as I will be installing one in Kabul-Afghanistan and need all info for this device to be installed properly. I thank you in advance. Reply |
0Replies9 years ago | change of the reagents. I'd just know,please,if it's better to change the 3 reagents at the same time(even when the diluent is finished,and the lyser and the cleaner not)or we can change them separatly. My hematology analyser is Abacus 380. Thank you for responses. Reply |
Reliable - The long lifetime diode laser, diagnostic flagging system, and cap recognition feature ensures optimal performance at all times and prevents sampling errors.
User friendly - A large, color touch screen allows easy, fast, and efficient operation. The integrated barcode reader provides safe and rapid sample processing either manually or via an optional 100-sample capacity autoloader. This hematology analyzer features a logical multi-lingual operating menu and the Windows-based software enables easy connection to a host computer and printers. Results are displayed with 2 histograms and 2 scattergrams to provide maximum patient information.
Efficient - The Abacus 5 provides a complete 26 parameter report including optical determinations of the 5-part WBC differential count. It offers open and closed tube sampling options and has a throughput of 60 samples per hour in either stat or autoloader mode. In addition, the analyzer has a 100,000-result database capacity.
Space saving - The Abacus 5 hematology analyzer is one of the smallest 5-part differential analyzers, requiring minimal bench space. This makes it an ideal system for use in space-restricted environments such as clinics and small to medium laboratories.
Cost Efficient - The Abacus 5 uses only 3 reagents to perform an analysis, plus a small volume of cleaner, thus providing a 5-part differential result at a very competitive price. In addition, this hematology analyzer requires minimal maintenance, thus reducing its operational downtime.
Case Study Book Case Study Book is available for perfect interpretation of scattergrams.
Throughput: 60 tests/hour
Parameters: a CBC+5 DIFF mode (26 parameters) - 2 histograms: RBC, PLT; 2 scattergrams: 4 diff, WBC, LYM, MON, NEU, EOS, BAS, LYM%, MON%, NEU%, EOS%, BAS%, RBC, HCT, MCV, RDW (sd/cv), HGB, MCH, MCHC,PLT, PCT, MPV, PDW (sd/cv), P-LCC, P-LCR
Laser light scattering technology for 5-part WBC differential
Sample volume: 110 μl of whole blood
Closed and open tube sampling, optional autosampler
3 cyanide-free reagents: Diluent, Lyse, Stopper
Data storage capacity: 100,000 records
Operating environment: Temperature: 15–30 °C
Relative humidity: Max 80% (non-condensing)
Multilingual user interface: English, French, Spanish, Croatian, Hungarian, Italian, Polish, Portuguese, Russian, Turkish, Chinese, German, Greek
Size (Width x Depth x Height) 40 cm x 50 cm x 45 cm, 16” x 20” x 18”
Weight - 35 kg, 77 lbs
