Thermo Fisher Scientific - HM 355S
Microtome
Motorized heavy-duty automated rotary microtome designed for all applications of paraffin, semi-thin, and hard specimens in clinical, research, and industrial labs. Menu-driven control panel with large display and large-sized knobs can be moved to either side of microtome for user comfort. Selectable, integrated specimen retraction. Piezo (variable) knob controlled advance and retraction. Wing-style dove-tailed knife support stage provides for greater stability. Removable blade carrier levers help protect settings; protective blade guard design moves blade without exposing blade edge. Vertical movement on maintenance-free cross roller bearings. Section thickness ranges from 0.5 to 100µm; specimen trimming function with defined steps from 5 to 500µm. Specimen advance of 28mm through stepping motor technology. Integrated waste try with arm rest. Emergency stop through handwheel, push-button on control panel, or foot pedal.
FORUMSView All (5)
1Reply3 months ago | Error Code I'm getting an error code 003-011 any idea Equipment: Thermo Fisher Scientific - HM 355S Reply |
5Replies7 months ago | HM 355s error message Hi, somebody how knows how to exchange the battery, and where it is located? I get Error message: "low battery" Reply |
3Replies2 years ago | Error y se bloquea Hola. Me sale Error 003-011 en la pantalla y tengo que quitar todos los cables y probar a reiniciarlo varias veces hasta que arranca. Que puede ser?? Gracias.Reply |
- Menu-driven control panel can be used on either side of instrument
- Display monitors a range of functions including cutting speed, section count, section thickness, and advance distance
- Four cutting modes of operation (single, interval, multi and continuous)
- User-selected cutting window control maximizes throughput by allowing the return stroke to be faster than the optimized cutting stroke
- Manual and/or foot pedal control
- Double tap start activates sectioning motor
- One-handed zero-orientation head
- Joy-stick control specimen advance and rewind
- Emergency stop immediately cuts power to the motor
- Five languages available for viewing commands
- Large, easy-to-clean waste tray extends below the blade holder
- Cutting stroke: 72 mm
- Total specimen advance: 28 mm
- Maximum sectioning speed: 400 mm/s
- Section thickness range: 0.5-100 μm
- Trim thickness range: 5-500 μm
- Retraction range: 40 μm
- Section counter: Standard
- Dimensions (D x W x H): 20.5 x 16 x 11 in. (52 x 41 x 28 cm)
- Weight: 77 lb. (35 kg)
