Diatron - Abacus Junior 5
by Diatron
Hematology Analyzer
Abacus junior 5 offers an optimal solution for clinics and physician practices which require high quality 5-part WBC differential results. Thanks to the cap pierce feature it can be used in open and closed tube mode. It has large data storage capacity for measurements and histograms.
FORUMSView All (8)
-KADRI
Mon Dec 19 2016
Vacuum error
In urgent my device ABACUS JUNIOR5 displayed empty "Vacuum error" ...Reply
2
-KADRI
Tue Aug 23 2016
abacus juni 5
FNS my abacus PLC junior5 it gives error flag: pHReply
-KADRI
Tue Aug 23 2016
error for abacus ju5
hello my friend I have a probleme.des ABACUS JU5.il analysis gives the following message: "blood detectore calibration falled"
  • Offers 22 parameters with high quality
  • 5-part diff results based on cyto-selective eosinophil and basophil reagents
  • Instrument can also be used in the 3 part diff mode
  • 20 tests /hour
  • Open or closed tube sampler system
  • Sample volume: 90 µl of whole blood
  • Measured parameters: 22 parameters
  • Including 5-part WBC differential: WBC, LYM, MON, NEU, EOS, BAS, LYM&#037, MON&#037, NEU&#037, EOS&#037, BAS&#037, RBC, HCT, MCV, RDW, HGB, MCH, MCHC, PLT, PCT, MPV, PDW Reagents*
  • Isotonic Diluent, Lyse, Lyse EO, Lyse BASO, Cleaner
  • Throughput: 5 part diff mode: 15 test/hour 3 part diff mode: 22 test/hour
  • Sampling method: Open or closed tube sampler system with automatic sample rotor
  • Built-in printer: Easy Paper Operation thermal printer, 56 mm wide roll paper (optional)
  • User interface:Easy-to-use, menu driven user interface with 6 software buttons (with icons), 6 hardware function buttons, cursor and numeric keys
  • Dimensions (WxDxH): 320 × 260 × 365 mm
  • Net weight: 14 kg
