Diatron - Abacus Junior
by Diatron
Quality, precision and portability at an affordable price
Abacus junior provides complete 18-parameter hematology profiles
in about 2 minutes with no preparation time. All required functions
can be accessed from an optimized user interface, enabling the user to
work fast and efficiently. The large back-lit LCD allows rapid,
accurate patient data entry and monitoring of the test results,
including 3 large histograms. Abacus junior is designed to be practically
maintenance-free, with minimal disruption to your practice.
FORUMSView All (6)
-shamim hoosen
7 years ago
abacus 5 and abaacus 5 junior
what is the difference in technology between the Abacus 5 and the Abacus 5 junior.
-cismaru
13 years ago
mesaj 5008/1059
am un ABACUS JUNIOR imi apare un mesaj: the volume of the diluent is running low, ce inseamna si ce trebuie facut?Reply
-insaf
13 years ago
i have quation aboute error p and battery afished 2.7volt
i have quation aboute error p and battery afished 2.7voltReply
  • The instrument features a sophisticated but easy-to-use, logically constructed, multilingual operating menu.
  • It provides 6-level QC, L-J graphs and self-diagnostic functions to let you monitor reliability and accuracy.
  • The large graphic display offers selectable multi-user modes, device statistics, icons and function keys.
Sample volume: 25 µl whole blood (50 µl in Prediluted mode)
Aperture diameter: 80 µm (in one universal measuring chamber)
Throughput: approximately 30 tests/hour
Sampling method: Open tube system with automatic sample rotor
Sample types: Human (general), Male, Female, Baby, Toddler and
Child
Fault statistics: RBC/WBC clogging < 1% of analyses (normal use)
Clog prevention: High-voltage pulse and chemical cleaning of the
aperture in each analysis cycle using Cleaner
reagent
Cleaning procedure: High-voltage burst of aperture, high-pressure backflush,
chemical cleaning of aperture using Cleaner
Quality control: 6 levels, including: mean, ± range, SD and CV for all
measured and calculated parameters, 16- and 64-
day Levey-Jennings charts, separate QC database
Calibration: Automatic based on 1 or 3 measurements, or manual
calibration of WBC, HGB, RBC, PLT, MCV, RDW,
MPV (separate factors for prediluted mode),
monitoring of calibration factors by calibration events
Multi-user feature: 3-level multi-user operation with selective privilege
levels, user identification with ID and password
User interface: Easy-to-use, menu driven user interface with 6
software buttons (with icons), 6 hardware function
buttons (above LCD), cursor and numeric keys
Languages available: Chinese, English, French, German, Greek,
Indonesian, Italian, Persian, Polish, Portuguese,
Romanian, Russian, Spanish, Vietnamese
Data storing capacity: 1000 results, including histograms
Host computer interface: Serial (RS-232) computer link
Data back-up Interface: 3.5 floppy disk
Software upgrade: 3.5 floppy disk or slim CD-ROM (optional)
Printer interface: Centronics (parallel) or USB (optional)
Optional built-in printer: Easy Paper Operation built-in printer module
Display: 240x128 dots high-contrast, backlit, graphics LCD
Keypad: 24 foil keys + START button
External keyboard: Standard PS/2 compatible keyboard
Power supply: Universal, external 12VDC, 8A power module
Power supply (input): 90-260V, 50-60Hz, 10W stand by, 80W max.
Operating temperature: 15-35°C
Dimension (WxDxH): 320 x 260 x 365 mm
Net weight: 12 kg
