Sakura - Accu-Cut SRM 200
by Sakura
Microtome
Compatible with Accu-Edge® Disposable Blades, the Accu-Cut® SRM™ 200 ensures superior sectioning in the precise art of cutting quality tissue samples section after section, time after time.
The SRM™ 200 ensures secure, precise positioning of specimen block with universal cassette and orientation clamps while facilitating exact, rapid trimming via a trimming lever, which enables specimen advancement of 10 or 50 microns. Micron thickness is handled by an adjustable visual display to ensure accuracy. A universal blade holder base, featuring lateral displacement, allows operators to use the full length of the microtome blade without releasing the blade clamping mechanism or direct blade manipulation.
The SRM™ 200 hand wheel is designed to run smoothly, minimizing hand stress for maximum efficiency and productivity. Finally, a sliding cover protects against sectioning debris, allowing minimal cleaning and maintenance.
FORUMSView All (4)
-Monarkjohn
4 years ago
Chuck holder assembly loose
I took off the chuck holder assembly to access inside microtome. After putting it back together the lock down lever at rear of assembly which locks the up down left right adjustment wont tighten. Any ideas.Reply
2
-cuasman_9005
5 years ago
Service manual needed.
Does anyone have a service manual for this. Need a breakdown on the knifeholder locking mechanism. Specifically the lower part from the middle locking lever breakdown. ThanksReply
2
-markf
6 years ago
manual needed
Does anyone have a service manual, or even a user manual for this? ThanksReply
  • Universal cassette clamp and orienting clamp
  • Adjustable trimming lever
  • 10 or 50 micron advancement
  • Compact, ergonomic design
  • Smooth-running hand wheel
  • Adjustable visual display of micron settingUniversal blade holder base with lateral displacement feature
  • No manual blade manipulation
  • Designed for use with Accu-Edge® Disposable Blades
  • Sliding cover
  • Available as a retracting or nonretracting microtome
  • Product Codes: #1429 (with retraction)   #1429N (without retraction)
  • Dimensions: Centimeters (W x D x H): 40 x 47 x 29
  • Inches (W x D x H): 15.8 x 18.5 x 11.6
  • Weight: 29 kg (64 lb) without accessories
  • Section Thickness Range: 0.5 – 60 µm
  • Specimen Retraction: 220 µm
  • Trimming Steps: 10 µm or 50 µm
  • Displacement of Blade Holder Base: Vertical and horizontal directions
  • Compatible Blade Types: Disposable high- and low-profile steel knives
  • Disposable high- and low-profile blades
  • Reusable steel knives
