Hematology Analyzer
The ABX Pentra DF 120 SPS Evolution hematology analyzer features autoloader with continuous loading capability, automatic reflex testing and validation station with cytology atlas. It offers automatic re-run of samples and its balance concept enables automatic control of the leukocyte count based on three independent channels.
- Methods of measurement: Cytochemistry, impedance, absorbance and flow cytometry
- Balance Concept: Automatic control of the leukocyte count based on 3 independent channels
- DHSS: Focused flow cytometry and sequential measurement (impedance and absorbance)
- Automatic re-run of samples: Selective and programmable (hematology parameters alarms and flags)
- Rotative mixing of samples: Smooth and efficient
- Liquid valves ABX (no pinch valves): Reliability and volume accuracy
- Weight 170 kg
- Power supply 100/240 V - 50/60 Hz - 700 W laser in stand-by 800 W, (2kW maxi).
- Dimensions 75 x 167 x 55 (H x W x D) cm
- Printer Laser printer
- Throughout 120 tests/hour
- Data processing- OS9 Floppy disc, RS 232C, Mono and bi-directional connection
- Compliance- ASTM protocol
- Memory capacity- 90 000 results + graphics
- Parameters (32)- WBC, RBC, HGB, HCT, MCV, MCH, MCHC, RDW, PLT, MPV,PCT*, PDW*, NEU, LYM, MON, EOS, BAS, ALY, LIC, IMM, IMG, IML: (% and #)
- Graphs-High-definition DIFF matrix, PLT, RBC, WBC/BAS curves
- Volume-Manual mode : 130 µL Automatic mode : 200 µL
- Slide- 50 µL
- Stability- Up to 48 hours for CBC/DIFF
- Operating sample mode- Autoloader 15 racks (150 tubes) capacity Sample mixing in end-over-end rotation mixing Open tube in STAT mode
- Identification - Alphanumeric, Bar-code reader (internal and external) Automatic impression in indelible ink on itch slides (3 lines)
