Signa Vibrant is the most complete, dedicated breast MR scanner available.GE Healthcare is committed to leading the fight against breast cancer, the second leading cause of cancer death in women.
Signa Vibrant is the most complete, dedicated breast MR scanner available. Named after GE Healthcare's groundbreaking acquisition technique, it is uniquely designed to enhance patient comfort and provide confident imaging from acquisition through interpretation.
Ask a New Question1Reply-Greenboy Fri Jan 22 2021 | Fri Jan 22 2021TPS Error Hi,
What is a TPS error on MRI.15t GE? Does it show up instantly ? Or the system keeps telling you prior to a complete software failure? an expert feedback would be highly appreciated.
Many thanks
AlexReply |
- Lays the foundation for a complete solution with a superior combination of high spatial detail and scanning speed.
- Uses the GE exclusive GEM acceleration technique to further accelerate the scanning speed of GE's patent pending VIBRANT technique. With VIBRANT-XV users can acquire higher resolution faster. VIBRANT-XV still allows the choice of direct sagittal or axial imaging making it easy for users to satisfy clinicians, and automatically optimizes parameters making it easy for user technologists to give users consistent image quality.
- Collects two echoes with water and fat, spins in- and out-of-phase and utilizes a two-point Dixon technique to synthesize water and fat images. Vibrant-Flex optimizes acquisition with a high signal-to-noise ratio (SNR) for acquiring high quality water and fat images. This capability lets the user prescribe thinner slices for high spatial resolution imaging.
- Image both breasts in high resolution in one patient visit.
- Perform a bilateral breast exam in both the sagittal and axial planes with the same resolution and scan time as a single-breast MR study.
- Obtain high temporal resolution without sacrificing spatial resolution.
- Eliminate fat with absolute reliability and confidence.
- Utilize the bilateral breast imaging technique that is the most sensitive to their patients' diagnostic needs.
- Perform procedures that can have a positive economic impact on their practice.
- Enhances diagnostic confidence by improving the ability to characterize lesions and monitor response to therapy.
- It is a breast-specific, single-voxel spectroscopy application designed for ease-of-use and enhanced visualization.
- A single voxel spectroscopy technique that has been designed specifically for the breast. It is designed to enhance their diagnostic confidence and uses an optimized signal detection technique to reliably visualize the presence, or absence, of a choline peak. In addition, BREASE is easy to use – the technologist simply places the voxel over the area of interest.
- The Vanguard Breast Table developed and sold by Sentinelle Medical - is a unique solution with a Variable Coil Geometry (VCG) for optimal positioning of coil elements.
- HD Breast Array provides approximately 30% more SNR than exams done without the HD Breast Array, enhancing the performance of VIBRANT and providing excellent lateral and medial access for biopsy procedures.
- 8-channel HD Breast Array 8-channel, 8-element phased array design Optimized for parallel imaging techniques Biopsy compatible for both medical and lateral approaches PURE compatible
- CADStream by Confirmation automatically generates the post-processed series and helps identify the most suspicious washout curves. Sureloc, included with CADstream, enables productive planning of MR-guided biopsies from the console.
| Clinical Use | Whole Body |
| Magnetic Field Strength | 1.5 T |
