Zoll - M Series
by Zoll
A Defibrillator Model for Every Application – One User Interface
ZOLL M Series® defibrillators are a family of products to meet your clinical needs from BLS to ALS. Products range from AED and advisory defibrillators to manual units and Critical CareTransport (CCT) units. Thanks to the consistency built into each and every defibrillator unit, you train once and use everywhere. Standardization has never been so easy.
FORUMSView All (42)
-migues
Tue Sep 24 2024
Service Manual
Error ICU 314
Equipment: MSERIES
-neagustefan
Sat Dec 09 2023
Cannot remove the front panel (with the display)
the manual says to unscrew the 2 long screws on the bottom then insert thumbs in the main knob well and push up. However the front panel doesn't move at all when doing this. is there an additional step or tool required? thank you, Stefan
-Sepide
Mon May 15 2023
error fault 72 and fault85 and defib disable.
My defibrilator gives error fault 72 and fault85 and defib disable. Does Anyone konw what the problem is?
Equipment: Zoll m series error
SERVICE COMPANIESView All Defibrillator Companies
[list]    [*] The smallest, lightest, brightest defibrillator unit in its class makes for easy handling and optimal viewing while the built-in AC power and battery charger doesn’t add size or weight        [*] The ZOLL Uniform Operating System features consistent, straightforward controls; intuitive menus lessen training costs, minimize operator confusion, and reduce the chance for error        [*] ZOLL’s proprietary Rectilinear BiphasicTM waveform with its lower energy and current and the 40-msec Rectilinear Pacing waveform provides superior efficacy while optimizing patient safety        [*] ZOLL’s patented external Pacing offers superior capture at lower mean thresholds, reducing muscle artifact and ensuring more patient comfort and better patient tolerance        [*] Offers defibrillator event documentation via internal memory, as well as removable PCMIA cards for easy data transfer and archiving. Coupled with CodeNet®, ZOLL’s unique PDA-based data management system, the M Series communication capability makes record keeping a breeze        [*] A wide variety of defibrillator electrodes and paddles are designed to meet your every need, and pre-connection capability and common connectors help reduce stress in critical situations        [*] Now available with Real CPR Help®        [*] ZOLL’s M Series defibrillator upgrades provide maximum performance and flexibility in every product with add-ons designed to perform to your exacting standards        [*] 12-Lead ECG is available in standard analog for fax transmission or digitally for real-time transition with virtually any available communication technology        [*] Pulse Oximetry / SpO2 uses Masimo SET® signal processing technology for accurate measurements in the presence of motion, high ambient light and low perfusion and when pacing        [*] EtCO2 features Respironics® Novametrix End Tidal CO2 monitoring with interchangeable mainstream or sidestream sensor options to accommodate all patients        [*] Non-invasive Blood Pressure (NIBP) defibrillator monitor offers single, stat, or fully automated functions for optimal patient assessment no matter the circumstances. Invasive Blood Pressure (IBP) is also available    [/list]
Defibrillator TypeExternal, Automated (AED)
