CAS Medical - AMI Plus
by CAS Medical
Ami Plus is an infant monitor for home use. It is small lightweight, easy to use, offers leading edge technology and has a history of performance.
  • CAS Express™ software for streamlined data analysis
  • Internal modem for fast data transmission
  • Interfaces with CASMED’s Easy II Sleep Pediatric System
  • Interfaces with the latest pulse oximetry technology
  • enhanced respiration detection, backup alarm and environmental seal for            superior safety and reliability
  • a long battery life with simple battery pack replacement, standard A/C power            cord and easy-to-read signal-quality indicator for simple operation
ECG
Heart Detection: 30 - 265 BPM, 0.2mV to 5mV
Minimum Signal: 0.2 millivolts
Heart Slow Limit: 40 - 130 BPM (5 BPM increments)
Heart Fast Limit: 125 - 250 BPM, OFF (25 BPM increments)
Loose Lead Threshold: Base impedance greater than 1700 Ohms, nominal
Heart Rate
Alarms: User selectable, low heart rate and high heart rate
Bradycardia Options: 3 Beat, 6 Second Max. 5 Second Max. Only
Respiration
Range: 10 - 150 BrPM, 0.2 Ohms to 5 Ohms
Minimum Signal: 0.2 Ohms
Apnea Delay: 0 - 30 Seconds (5 sec. increments)
Line Power
120 VAC, 50/60 Hz, 0.5A
230 VAC, 50/60 Hz, 0.25A
Battery Power
Dealer replaceable battery pack
Rechargeable NiCad
Battery Operation: 20 hours continuous use
(average)
Recharge Time: 5 hours
Lithium Battery: For memory back up
