Leica Biosystems - TP1020
Semi-enclosed tissue processor.
Gentle specimen processing and maximum safety at all stages of processing are the result of robust engineering design based on proven and precise mechanics in conjunction with a modern user interface.
FORUMSView All (12)
1Reply2 months ago | W 03 error with melted paraffin Hi I have a problem that the basket does not go down in the #12 position because it appears the W03 code error. Paraffin is melted and has the correct temperature to operate. I tried changing the jar of paraffin with another jar and the error was still there. Thank you Equipment: Leica TP 1020 Reply |
1Reply6 months ago | looking for service manual I have TP1020 Leica Tissue processor with error E03; it has been just more than a year since installation. Please share the service manual with me. Thanks Equipment: TP1020 leica Tissue processor Reply |
1Reply3 years ago | Service manual I need service manualReply |
[list] [*] Carousel type with 12 stations [*] Configurations: Basic instrument, Vacuum function, Fume control system, Vacuum function with fume control system. [*] Option: two basket loading [*] Tissue baskets made of metal with varying capacities of up to 80 cassettes [*] Ergonomic control panel with foil-protected keyboard and LCD [*] Infiltration time separately programmable for each station. [*] Delayed start function up to 9 days [*] Possibility of interrupting an automatic process for reloading or removing cassettes for special applications before the end of a run [*] Easy editing and changing of programs, even during a processing run [*] Audible alarms, error messages and warning codes [*] Advanced safety concept [*] Wide range of accessories [/list]
Electrical: Nominal voltage: 100/120/230/240 VAC +/- 10% Nominal frequency: 50/60Hz Dimensions: Carousel lid: 820 mm Height: 595 - 780 mm Diameter of rollers: 610 mm Weight: Dry weight including accessories: 60 kg Wax baths: Number: 2 (3 optional) Capacity: 1.8 Temperature range: 45°C - 65°C Excess temperature cutout: 75°C +/- 4°C Reagant containers: Number 10 (9) Capacity: 1.8 Standard tissue basket: Number: 1 (2 optional) Capacity: approx. 80 cassettes
