Sakura - TISSUE-TEK Rotary Tissue
Rotary Tissue Processor.
The Rotary Tissue Processor is an instrument for automatically processing human and animal tissue specimens. Tissue specimens are enclosed unlabeled Uni-Cassettes® and placed in the wire mesh basket. The movable hood raises, transports and lowers the basket through a series of ten glass beakers containing the processing reagents and two stainless steel pots containing molten paraffin. The tissue is sequentially submerged and oscillated in the reagents throughout the programmed processing cycle. The reagent immersion time for each beaker is programmed on a 24 hour timing disc with 12 movable control stops with 15 minute increment.
0Replies3 years ago | Tissue Tek Xpress X50 Tissue Processor The image shown here is actually a Sakura Tissue Tek Xpress X50 Tissue Processor. I think that the Rotary Tissue Processor is a much older machine, similar to a VRX-23 Tissue Processor. |
0Replies10 years ago | Sakura Tissue Tec Rotary Tissue Processor Problem We have a rotary tissue processor having problem. After single cycle when its circular hood moves up after it then it doesnt moves to next station If you have service manual of Tissue Tec Rotary Tissue Processor Service manual then kindly email to engineer.awais1@gmail.com Thanks and Regards Reply |
- Consistent processing in 1 hour
- An efficient, manageable continuous workflow
- Same day results by real reduction of turn-around time
- Reduction of reagent usage up to 80% Formalin and Xylene-free fixation processing
Cassette Printer 900 cassettes per hour Slide Printer-800 slides per hour W x D x H= 46 x 65 x 94 cm
