Sakura - Tissue TEK XPRESS-120
Tissue Processor.
The Tissue-Tek® Xpress® x120 utilizes breakthrough microwave technology, optimized molecular-friendly reagents, and proven vacuum infiltration techniques, and permits processing biopsy and routine specimens in the same run, while still maintaining specimen integrity. You can expect continuous throughput yielding up to 960 cassettes in an 8-hour shift. Up to 40 cassettes can be loaded every 20 minutes. And the total volume of reagents used is reduced by about 80% compared with traditional methods. Reagents are presented ready-to-use in disposable containers. This gentler process preserves DNA, RNA, and proteins in the paraffin block when specimens are processed fresh or pre-fixed with Tissue-Tek® Xpress® Molecular Fixative.
4Replies8 years ago | Service/Maintenance/PM We purchased 2 Xpress Processors from a 3rd party vendor and have had them for 3 years. PMs have been performed annually and both are used daily. We are looking for another company/technician to provide us service on these processors. Does anyone know of a company or technician that would be interested? Reply |
5Replies8 years ago | Bubble Pump for Retort 1 on a Sakura Xpress X120 This message is in regards to our Sakaura Xpress X120 Processor. Issue: We are not getting any bubbles in retort 1 causing error 1255 (Bubble pump Malfunction) . It is also keeping the temperature from getting high enough to start the processor.
Thank you for any help you can provide. Reply |
- Closed system, minimizing chemical exposure 1 loading station, 4 reagent retorts, and 2 unload stations
- Consistent circular microwave patterns
- Compatible with H&E Special staining methods
- Reagents do not contain formalin or xylene
- Compatible with formalin-fixed tissue
- No retort cleaning cycles necessary
Product Code: #7720 Dimensions: Centimeters (W x D x H): 64 x 67 x 28 Inches (W x D x H): 162 x 170 x 71 Weight: 1012 lb (459 kg) 200 VAC 60Hz 15A Single phase Nema L6-20, dedicated
