Sakura - TISSUE-TEK Xpress x50
Continuous rapid tissue processor.
The Tissue-Tek® Xpress® x50 processes up to 440 specimens in an 8-hour shift, with the ability to load up to 40 cassettes approximately every 45 minutes. It provides outstanding time and cost savings, as well as increased staff safety, while producing standardized, accurate results paralleling those from overnight processing, allowing same-day diagnosis and, ultimately, improved patient care.
- Closed system, minimizing chemical exposure 1 loading station, 2 reagent retorts
- Consistent circular microwave patterns
- Reagents do not contain formalin or xylene
- Compatible with formalin-fixed tissue
- Compatible with H&E Special staining methods
- No retort cleaning cycles necessary
Product Code: #7750
Dimensions: Centimeters (W x D x H): 64 x 33 x 28
Inches (W x D x H): 162 x 85 x 72
Weight: 617 lb (280 kg)
115 VAC
60Hz
12A
Single phase
Dedicated line required
