Triangle Biomedical Sciences - ATP1
by Triangle Biomedical Sciences
Tissue Processor.
The ATP1 is the only tissue processor to direct the flow of all reagents, waxes and cleaning solutions to and from the processing chamber through a single rotary valve within a heated chamber. Totally Enclosed Reagent/Pneumatic System Eliminates Noxious Vapors No problematic overfill sensors are required to regulate retort filling or to minimize the escape of toxic fumes due to retort over-filling. Unique reagent bottle design in combination with chamber over fill collection system eliminates the adverse effect of overfill conditions by providing for the uptake of any excess reagent back into the appropriate reagent container.
-mihai.baltatescu
13 years ago
ATP 1 Tissue Processor
i need a technical manual for this deviceReply
  • Single rotary valve reduces reagent carryover
  • Totally enclosed reagent/pneumatic system eliminates noxious vapors
  • 8" color LCD touch screen controller improves operator viewing and efficiency
  • Unique "Bubbling" technology maximizes fluid exchange Innovative design minimizes downtime and reduces service costs
CAPACITY: Max. 350 cassettes
CONTAINERS QUANTITY CAPACITY/TYPE TEMPERATURE
Paraffin 4, plus 1 reserve 2.5 L - 3.0 L 50 to 60° C (+/-1)
Reagent 10 2.5 L - 3.0 L Amb to 45° C (+/-1)
Cleaning 2 1 Clearant/1 Dehydrant
Filtration 2 Charcoal
DISPLAY: 8 Diag. Color VGA (640 x 480) display w/built-in touch-screen controller
FLUID EXCHANGE: Adjustable bubble rate: off, 15, 20, or 30 min. intervals
Vacuum: -700mBar (-70KPa)
Pressure: +250mBar (+25KPa)
DIMENSIONS: Floor Model (53H x 21W x 24D)in (134H x 53W x 60D)cm
Bench Model (31H x 42W x 24D)in (77H x 105W x 60D)cm
WEIGHT: Actual: 264 (lbs), 120 (kg) Shipping: 330 (lbs), 150 (kg)
ELECTRICAL: 115VAC, 60Hz; 8 Amp max.
220VAC, 50Hz; 4 Amp max.
100VAC, 50/60Hz; 9 Amp max.
Max Power 1400W
For International shipments specify requirements.
WARRANTY: 1 Year, parts and labor
