Thermo Fisher Scientific - Shandon Finesse 325
Microtome
The Shandon Finesse 325 is a manual rotary microtome for routine paraffin sectioning. It has a lightly balanced flywheel designed to address repetitive stress injury. The Shandon Finesse 325 includes an integral debris tray, organizer storage tray and a resettable section counter. The retraction feature is standard and may be disengaged at the user?s request. The unit is supplied with a quick release cassette clamp and "x-y" orientation head as standard. Disposable blades or standard microtome knives may be used with this unit, using the appropriate knife holder.
FORUMSView All (4)
0Repliesa year ago | PARTS HI NEED ANY INFORMATION ABOUT THE TIMING BELT REPLACEMENT, TYPE, SIZE, LENGTH NUMBER PART ,ETC. THANKS Equipment: Thermo Fisher Scientific - Shandon Finesse 325 Reply |
1Reply2 years ago | Belt for rewinding specimen her Hi dear someone told me about the specifications and size of the belt which is use for microtomes heads movement and rewinding it on 0 position for Shan don finesse 325 and any information to fix it thanks Reply |
12Replies3 years ago | Service manual I need shandon 325 service manual plz share someone With thanksReply |
- Quick-release cassette clamp and x-y orientation head supplied as standard
- Disposable blades or standard microtome knives can be used with this unit (with the appropriate knife holder)
- Modern Accu-Feed System provides high-quality, reproducible sections throughout the length of specimen travel
- Accu-Feed specimen advance is selectable in 1μm steps from 1 to 30μm
- Specimen tilt / orientation is ±5 degrees using X-Y micro adjustment
- Precision response, free-running flywheel with ergonomic design
- Removable deep debris tray for easy cleaning
- Dimensions : 11.4” x 16.1” x 19.7” (29 x 41 x 50 cm
- Weight : 88 lbs. (40 kg)
