Siemens - ADVIA 2120i
by Siemens
Enhanced patient care through advanced testing technology
Only the ADVIA 2120i Hematology System can truly automate your hematology lab without the need for large track-based systems, expensive stains, or reflexive testing. The ADVIA 2120i system streamlines workflow by eliminating the majority of manual steps commonly performed to maximize productivity. It delivers the gold standard in testing methodology for optimum results while offering the simplicity and flexibility you need for easy integration into your lab.   Put the power of true automation to work for you. Have a look at the product features page for detailed information about benefits the ADVIA 2120i system has to offer.
FORUMSView All (8)
-klewis
Fri Apr 17 2020
operators guide
environmental requirements?Reply
-Shellfire
Sat Mar 02 2019
LIS Integrations
The Advia is not sending a results message to my LIS. The Advia shows Green for LIS connection and shows that the sample has moved to All Complete. However inspecting the SPY file on the Advia shows that it never sends a results message, just toggling the Token Transfer message. Any help or insight would be greatly appreciated!Reply
-guessoum1954_7106
Wed Dec 20 2017
Documentation
I'm looking for a amnual service and operation manual in french languageReply
•Save laboratory personnel’s time, improve productivity and reduce costs with practical automation    •Results that are right the first time – Quality results for WBC differential, RBC, reticulocyte, PLT and CSF testing    •Scalable solution: From standalone to complete automation    Save laboratory personnel’s time   Only the ADVIA 2120i system gives you Practical Automation—the unique ability to eliminate the majority of manual steps commonly performed for maximum speed and productivity.             •Proven technology, reference methods, and onboard delta checks reduce manual slide reviews    •Fast, convenient, rack-based sampling: Any tube. Any time.    •High throughput of up to 120 samples per hour    •Results that are right the first time    •Efficient auto-validation procedures       Maximize productivity      Scalable solutions    Expanding your capabilities is easier and more affordable than ever with the ADVIA 2120i system. With integrated and automated solutions from Siemens, you can scale from stand-alone instrument to complete automation as your productivity needs change.             •Optional ADVIA® Autoslide Slide Maker Stainer gives you up to 120 high-quality slides per hour to scale up your productivity    •Network connectivity via ADVIA CentraLink® Networking Solution allows data management consolidation and QC management from any client workstation    •From truly practical automation to complete automation with the same instrument          Ease of use    The ADVIA 2120i system simplifies and streamlines all aspects of testing, allowing you to work faster and more efficiently so you can focus on other critical tasks.            •touch-screen monitor    •Unique reagent Time Pacs    •Three modes of aspiration: autosampler, open mode, and unique manual closed-tube sampling    •Unique Unifluidics technology—reduced fluidics, no pinch valves, automated daily cleaning    •Completely automated start-up       Quality results - Results that are right the first time    The ADVIA 2120i system uses gold-standard peroxidase staining for WBC differential testing.            •Fewer reruns   •Lowest overall review rate   •Faster turnaround time   •Lowest linearity—0.02-400k      The system also offers state-of-the-art technology for RBC, reticulocyte, PLT and CSF testing.    .RBC      •True RBC differential   •Consistent morphology   •Reduced manuals   •Unique dual-hemoglobin measurement capability— eliminates interference from lipemia      Automated Reticulocyte Analysis    •Direct measurement, not calculated   •Excellent in pediatric and dialysis populations         PLT   •Two dimensions—size and refractive index   •Measures up to 60 fl   •Includes large platelets in count   •Excludes fragments and microcytic RBCs      CSF    •Results in <5 minutes   •Linear to zero with three-part differential   •Automated counting provides quality control for consistency      .
