Siemens - ADVIA 2120
by Siemens
True RBC morphology advances cell separation to a new level that allows for the differentiation of various disease states, including those associated with anemia – no doubts, higher confidence, better efficiency.
Two dimensional optical platelets analyze both extra-cellular and intracellular properties, ensuring that large platelets are included in your counts, and known interferences are not – no doubts, higher confidence, better efficiency.
0Replies9 years ago | vetlab During a rinse or a clean there is an overflow of rinse solution forced out through the sample probe (OTS) as well in the Acts Reply |
0Replies10 years ago | ran wrong control I had completed the process for the perox lamp alignment and the set light intensity...I was then to run a normal control to verify Neut x and Neut y values. I ran the low control by mistake and now my differential values are incorrect with my neutrophils and my monocytes. How do I correct this? I tried doing the same processes again and running my normal control but it did not correct the values. Is there an easy fix for this problem? Reply |
1Reply11 years ago | supplies please help in providing supply order numbers for our advia stain and buffer. we are at st josephs medical center in the heights, houston, texas 77008 we use the stain,buffer combo for manual staining. gabriele scott Reply |
Customized Options Manage Your Workload - ADVIA 2120 Multispecies Software
•Supports 21 Species and Strains •Up to 30 additional user-defined species
.The ADVIA 2120 Hematology System - Now Playing in a Laboratory Near You.
•Proven Technological Productivity •Practical Automation •Real World Convenience
Performance Specifications
WBC 0.02 to 400 x 103/µL
RBC 0.0 to 7.0 x 106/µL
PLT 5.0 to 3500 x 103/µL
HB 0.0 to 22.5 g/dL
Retic 0.2 to 24.5%
Test Selectivity / Throughput
CBC 120 Samples/hr.
CBC/DIFF 120 Samples/hr.
CBC/DIFF/Retic 74 Samples/hr.
CBC/Retic 74 Samples/hr.
Sample Modes / Volumes
Automatic
Closed Tube 175µL.
Manual
Closed Tube 175µL.
Manual
Open Tube 175µL.
Weight and Dimensions
Analytical Module with Autosampler:
Weight 193 kg / 425 lbs
Height 86 cm / 33.8 in
Width 141 cm / 55.5 in
Depth 68 cm / 26.8 in
Analytical Module without Autosampler:
Weight 163 kg / 360 lbs
Width 81 cm / 31.9 in
Data Management
Data Base 10,000 Patient Storage Capacity
Including Graphics.
Review and Edit Capability: User Defined Windows
User Defined Reports
User Defined Ranges based on Age and Sex for Normal Range, Panic, Rerun and Delta Check Criteria
Bi-Directional and Host Query Communication Protocols.
Complete Quality Control Package: 3D bar and SDI graphs
Levey-Jennings plot
Table format
Patient moving average
QC file management
ILQC program
Remote QC
Extensive Online Documentation: Context sensitive field help
Operations manual
Procedure wizards assistance
Problem solving diagnostics
Remote diagnostics
Workstation Specifications
Windows 2000®
40 gigabyte hard disk drive
256 MB memory
CD-RW
17” Color LCD Monitor
Full size keyboard (major languages)
Physical Specifications
Electrical Power Requirements: Dedicated Line
Voltage Selectable for Single-Phase:
100 VAC (6 AMPS) – 240 VAC (3 AMPS)
Frequency: 50/60 HZ
Temperature Requirements: Operating: 18ºC – 32ºC
Storage: -40ºC – +70ºC
Relative Humidity: Operating: 15% – 80% (noncondensing)
Heat Generation – less than 3000 BTU’s.
Waste Disposal: Azide–free reagents drain into a waste
container with automatic level-sensor shutoff
Optional auto waste removal system
CN-free
Auto Sampler Option
150 Sample Capacity: 15 Racks with 10 tube capacity
Compatible Tube Types: VACUTAINER®, HEMOGARD®, Monovette®, Venoject®II, Venosafe®, Vacuette®, Monoject®
Bar Code Reader: Up to 14 digits
Automatic discrimination of label codes: Codabar
Interleave 2 of 5 with and without check digit
Code 39
Code128 EAN and JAN (8 and 13)
Other Specifications
Onboard analytical and wash reagents (1850 CBC/Diff tests).
Automated Daily Maintenance – fully programmable.
