Siemens - ADVIA Autoslide Slide Maker
by Siemens
Introducing the ADVIA® Autoslide Slide Maker Stainer - the smart solution for sampling on the ADVIA 2120 to consolidated smearing and staining. With a small footprint and no track, the fully automated slide maker stainer maintains big productivity to give you up to 120 high-quality slides per hour—significantly improving workflow. The ADVIA 2120 directs the ADVIA Autoslide through the intricate decision-making process necessary to produce the quality slides that make your hematology lab more efficient than ever.
Smart Sample User-defined reflexive slide sampling for the right results the first time. •Based on customized ranges, morphology flags and demographics •Aspirates small sample volume of 75 uL only upon decision for slide Smart Smear Classic wedge smear, no sample carryover. •Advancing tape technology •Adjustable smearing profiles •Positive slide identification •150-slide input capacity Smart Stain High-quality, single use reagents for each slide. •Dedicated staining wells •User-definable stain protocols •Stained slides delivered automatically in racks •Accommodates pre-smeared slides Smart Software Flexible user interface. •workstation •Single LIS interface through ADVIA 2120 •Automated maintenance ADVIA 2120 Hematology System with ADVIA Autoslide: Working together to receive rave reviews in your hematology laboratory.
Overview System Description Automated slide maker and stainer Reflexive slide preparation based on user-defined criteria for ranges, morphology flags, location, doctor, age/gender Samples and Sample Handling Sample Requirement 75 uL whole blood Slide Identification User definable, up to 3 lines of 14 characters Environmental Operating Temperature 20-30°C Operating Humidity 30-60% RH Electrical 100-240 v ± 10% Dimensions Width: 91 cm Noise Level Weight 60 kg (approx.) Smart Waste Management Biohazard waste separated from stain reagent waste
