Datascope - DPM4
DPM4 is a portable patient monitor ideal for use across a variety of clinical settings due to its compact size and simple design.DPM4 is a portable patient monitor ideal for use across a variety of clinical settings due to its compact size and simple design. Intended to meet basic continuous monitoring needs, it focuses on providing core capabilities in an uncomplicated manner. Its high resolution color display offers a surprisingly vibrant view of your patient's physiological data, making it practical for use at the bedside or during transport. Available with or without invasive blood pressure, DPM4 delivers the flexibility you need in order to properly respond to your patients’ changing needs. This very effective, yet surprisingly affordable monitoring solution is ideal for pre-operative areas, medical/surgical departments, general floors and beyond.
3Replies3 years ago | Monitor not retaining time Does anyone know what battery is used for the real time clock? The service manual, such as it is, is no help at all. I'm assuming a small lithium battery on the cpu board. The monitor is at a remote location, and I don't want to drive 2 hours just to take a look, then come back later with a battery. Any help with this is appreciatedReply |
[list] Standard Features: [*] 3/5-lead ECG [*] Non-invasive blood pressure [*] DPM SpO2 [*] Pulse rate [*] Respiration [*] Dual-channel temperature [*] Lithium ion battery [*] Integrated recorder Features and Benefits: [*] 8.4" TFT display, configurable up to 8 waveforms, enables maximum data analysis of your most critical parameters [*] Selectable display modes allow you to adjust data layouts based on particular patient circumstances [*] Comprehensive historical review of all parameters including 96 hours of graphic and list trends, 800 NIBP readings, and 70 alarm episodes [*] 40 seconds of full disclosure waveform recall for detailed review of physiological events [*] 3-trace recorder for printing real-time and historical data is included as standard [*] Compact flash back-up, included on every device, protects your patient data should a sudden loss of power occur [*] Nurse call interface allows connection into most hospital call systems [/list]
Height | 24 cm |
Length | 17.1 cm |
Weight | 5 kg |
Printer | Thermal Array |
Temperature Range | 0 to 40 °C |
Width | 26.1 cm |
Display Type: 8.4" color TFT Resolution: 800 x 600 pixels Waveforms: 8 selectable ECG (3 and 5-Lead) Leads: I, II, III, aVR, aVL, aVF, V Gain Selection: x0.125, x0.25, x0.5, x1, x2, auto Sweep Speed: 12.5mm/sec, 25mm/sec, 50mm/sec Bandwidth: Diagnostic Mode: 0.05-100Hz, Monitor Mode: 0.5-40Hz, Surgical Mode: 1-20Hz Defibrillator Overload Protection: Withstand 4000 VAC/50Hz voltage in isolation against electrosurgical interference and defibrillation Recovery Time: <5sec CMRR: Diagnostic Mode: =90dB, Monitor Mode: =105dB, Surgical Mode: =105dB Heart Rate Meter: Measurement Range: Adult: 15-300bpm, Pediatric: 15-350bpm, Neonate: 15-350bpm Accuracy: ±1bpm or ±1%, whichever is greater Resolution: 1bpm Respiration: Range: Adult: 0-120bpm, Pediatric/Neonate: 0-150bpm Resolution: 1bpm Accuracy: 7-150bpm: ±2bpm or ±2%, whichever is greater 0-6bpm: undefined Non-Invasive Blood Pressure: Measurement Method: Oscillometric Measurement Modes: Manual, interval, continuous Connector Type: Rectus Units of Measure: mmHg, kPa (user-selectable) Resolution: 1mmHg Systolic Range: Adult: 40-270mmHg, Pediatric: 40-200mmHg, Neonate: 40-135mmHg Diastolic Range: Adult: 10-210mmHg, Pediatric: 10-150mmHg, Neonate: 10-100mmHg Mean Range: Adult: 20-230mmHg, Pediatric: 20-165mmHg, Neonate: 20-110mmHg Accuracy: Mean error: < ±5mmHg, Standard deviation: < 8mmHg Cuff Deflation Technique: Step bleed Cuff Inflation: Volume of 500cc to 300mmHg in <20sec Over Pressure Protection: Double safety protection (hardware and software) Pulse Rate Range: 40-240bpm Pulse Rate Accuracy: ±3bpm or ±3%, whichever is greater Lead: I or II (default: lead II) Sweep Speed: 6.25mm/sec, 12.5mm/sec, 25mm/sec Invasive Blood Pressure: Measurement Range: -50 to 300mmHg Resolution: 1mmHg Accuracy: 1mmHg or ±2%, whichever is greater Zero Offset Range: ±200mmHg Excitation: 5VDC, ±2% Minimum load resistance will be 300Ω per transducer Frequency Response: DC to 12.5Hz ±1Hz, -3db Waveform Scales: ART: 0 to 300mmHg PA: -6 to 120mmHg CVP: -10 to 40mmHg RAP: -10 to 40mmHg LAP: -10 to 40mmHg ICP: -10 to 40mmHg IBP1/IBP2: -50 to 300mmHg Pulse Rate from Invasive Blood Pressure: Measurement Range: 25-350bpm Resolution: 1bpm Accuracy: 25-200bpm: ±1bpm or ±1%, whichever is greater. 201-350bpm: ±2% Pulse Oximetry: [i]With Masimo SET® SpO2[/i] Measurement Range: 1-100% Resolution: 1% Accuracy: ±2% (70-100%, Adult/Pediatric, no motion) ±3% (70-100%, Neonate, no motion) ±3% (70-100%, Adult/Pediatric/Neonate, motion) 0-69% unspecified [i]Pulse Rate with Masimo SET® SpO2[/i] Measurement Range: 25-240bpm Resolution: 1bpm Accuracy: ±3bpm (no motion), ±5bpm (motion) [i]With With Mindray™ SpO2[/i] Measurement Range: 0-100% Resolution: 1% Accuracy: ±2% (70-100%, Adult/Pediatric, no motion) ±3% (70-100%, Neonate, no motion) ±3% (70-100%, Adult/Pediatric/Neonate, motion) 0-69% unspecified [i]Pulse Rate with Mindray SpO2[/i] Measurement Range: 20-254bpm Resolution: 1bpm Accuracy: ±3bpm (no motion), ±5bpm (motion)
