Datascope - DPM5
by Datascope
DPM5 is a robust patient monitor, small enough to move around, yet flexible enough to adapt to your particular needs. With a variety of purchasable options including arrhythmia and ST analysis, ETCO2 measurement and multi-gas analysis, DPM5 is configurable to your liking. Pay for only the advanced features that you need and nothing more. With NIBP recall, extensive data storage capability, and well-established Microstream ETCO2 technology, DPM5 is particularly well-suited for the PACU environment. What's more, quick-action keys on the front panel make this device especially easy to learn, which means a shorter learning curve for new or changing staff. Rich in function, conveniently adaptable and pleasingly affordable, DPM5 may be just the monitor for your department.
2RepliesFri Oct 21 2016 | Clock will not stay set clock will not stay set. resets every time monitor shuts off Reply |
1ReplyTue Sep 17 2013 | mindray dpm5 how do I get into the calibration mode? Reply |
[*] Standard Features: [*] 3/5-lead ECG [*] Non-invasive blood pressure [*] DPM SpO2 [*] Pulse rate [*] Respiration [*] Dual-channel invasive blood pressure [*] Dual-channel temperature [*] Lithium ion battery [*] Integrated recorder Features and Benefits: [*] 12.1" TFT display, configurable up to 8 waveforms, enables maximum data analysis of your most critical parameters [*] 96 hours of graphic and list trends, NIBP list including 800 measurements, and alarm event recall for 70 alarm episodes [*] 40 seconds of full disclosure waveform recall for detailed review of physiological events [*] Microstream® ETCO2 technology provides fast, simple and accurate CO2 results on both intubated and non-intubated patients [*] Multi-gas analysis utilizes a sidestream method that automatically measures and identifies ETCO2, N2O, O2 and 5 anesthetic agents [*] Built-in, 3-trace recorder for printing real-time and historical data [*] Compact flash back-up, included on every device, protects your patient data should a sudden loss of power occur
| Height | 27 cm |
| Length | 13.7 cm |
| Power Requirements | 100-240 VAC |
| Weight | 4.7 kg |
| Width | 31.8 cm |
Display Type: 12.1" color TFT Resolution: 800 x 600 pixels Waveforms: 8 selectable ECG (3 and 5-Lead) Leads: I, II, III, aVR, aVL, aVF, V Gain Selection: x0.125, x0.25, x0.5, x1, x2, auto Sweep Speed: 12.5mm/sec, 25mm/sec, 50mm/sec Bandwidth: Diagnostic Mode: 0.05-150Hz (M08A module) Monitor Mode: 0.5-40Hz Surgical Mode: 1-20Hz Defibrillator Overload Protection: Withstand 4000 VAC/50Hz voltage in isolation against electrosurgical interference and defibrillation Recovery Time: 70bpm: ±5bpm CO2 with Oridion® Microstream®: Measurement Range: 0-99mmHg Resolution: Numeric: 1mmHg Waveform: 0.1mmHg Accuracy: 0-38mmHg: ±2mmHg 39-99mmHg: ±5% + 0.08% × (reading - 38mmHg) CO2 Waveform Recognition: 0-38mmHg: ±2 mmHg 39-99mmHg: ±5% of reading + 0.08% for every 1mmHg Start-up Time: 30sec typical. Reaches 5% steady-state accuracy within 3min Sampling Rate: 50ml/min: -7.5ml/min +15ml/min Auto-Zeroing Interval: At start-up, and every 12hrs thereafter Respiration Measurement Range: 0-150bpm Respiration Accuracy: 0-70bpm: ±1bpm 71-120bpm: ±2bpm 121-150bpm: ±3bpm
