Advertisement
BD Biosciences - FACSCount
Manufactured by BD Biosciences
An Industry-Leading System for Measuring Absolute and Percentage Results of CD4, and Absolute CD8 and CD3 Counts.
The BD FACSCount system is a proven, turnkey instrument and reagent system designed for CD4 counting to stage HIV/AIDS, guide treatment decisions for HIV-infected persons, and to evaluate effectiveness of therapy in a wide range of laboratory settings. As the system of choice for CD4 monitoring in global HIV/AIDS treatment programs for over a decade, the BD FACSCount system is recognized for its simplicity of operation, robust performance, and reliable results. Today clinicians in programs throughout Africa, Asia, Eastern Europe, and Latin America continue to rely on the system for cost-effective, simple, and dependable CD4 testing.
QUESTIONS & ANSWERSView All
Answers
-juliet meme
3 years ago
annual maintenance of bd facs count
Please what is the required volume of sample which needs to have been assayed on the BD FACS COUNT  before an annual maintenance can be done?
Answers
-BKONE
5 years ago
Dépannage
Bonjour
Quand j'éteint mon facscount il faut à chaque démarrage réglé l'heure pourquoi?
Merci
Answers
-NAYELEGONA
5 years ago
DATA SHEET OF SECIRITE OF REAGENT BD FACSCount / FICHE DE DONNEE SECIRITE DES REACTIF DU BD FACSCOUNT
Translation of originial post:
Hello, I am responsible for security in my laboratory at the General Hospital Issia in Ivory Coast where a nousutilison FASCount.
I wish I had the safety data sheets on the reagents used in this equipment.
Original post:
Bonjour, je suis responsable de la sécirité dans mon laboratoire à l'hôpital général d'Issia en Côte d'Ivoire où nousutilison  un FASCount.
J'aimerais avoir les fiches de donnée de sécurité sur les réactifs utilisés par cet équipement.
DOCUMENTS / MANUALS
PREVENTIVE MAINTENANCEView All
Be the first to submit a preventive maintenance post about this equipment
Easy to Install, Set Up, and Run with Confidence
The BD FACSCount system is easy to install. The instrument operates from a standard electrical outlet, requiring no hardware adjustments or calibration. Only minimal training is needed to set up the instrument and to run samples. Simple prompts on the display guide operators through testing, from input of patient information to final results. The software automatically identifies the lymphocyte populations of interest and summarizes patients’ results in a printed sample report. Quality controls in the software ensure that reported results are accurate by detecting and flagging error conditions and suppressing results when control limits are exceeded. Results are objective, requiring no interpretation or subjective analysis by the operators.
Quality control
To validate laboratory practice and methodology, BD FACSCount™ control beads can be added to samples prepared with normal blood. BD FACSCount fluorescent reference beads are included in the reagent tube, and ensure accurate enumeration of lymphocytes of interest with no operator intervention. The control run generates a detailed analysis in a printed report summarizing system performance. The result of the last control run is reported on subsequent sample printouts to help determine linearity and pipetting accuracy. Since absolute counts are calculated from directly measured cell counts and reference bead counts on the BD FACSCount system, no additional analysis on a hematology analyzer is necessary.
Simplified sample handling
Sample preparation follows an easy three-step process. First, blood is added to a tube that contains pre-measured reagents. Then the sample is vortexed and incubated. In the second step, a fixative is added to the tube, and then it is vortexed and incubated. In step three, the sample is vortexed and run on the instrument.
Easy three-step sample preparation
Prepare controls and patient samples by adding blood, then fixative solution, to the reagent tubes.
Advertisement
Ask anything about
Advertisement
For questions about using the MedWrench web site:
(866) 989-7057TOLL FREE  •  (770) 692-8371INTERNATIONAL
support@medwrench.com
MedWrench is in association with:
TechNationMedical DealerOR TodayMD Expo
Testimonials  •  Advertising  •  Privacy Policy  •  Terms and Conditions
© 2017 MedWrench, LLC. All Rights Reserved
Advertisement
