Biegler - BW 585
by Biegler
BW 585 blood and infusion warmer is a microprocessor-controlled device developed specially to avoid intra- and postoperative hypothermia.
In addition to the proven features of the BW 385/485-series, the BW 585 has a selector which allows the operator to set the warmer to a temperature between 37°C and 41°C in increments of 0,5°C. The special patented groove ensures that the tube is kept in the required position and also enables several infusions or transfusions to be warmed at the same time.
[list]      [*] Temperature can be set from 37°C to 41°C in 0,5°C increments         [*] Horizontal heating cylinder facilitates operation         [*] Several transfusions/infusions can be warmed at the same time         [*] Easy to read display         [*] Splash waterproof(IPX4)         [*] Low temperature alarm         [*] Extremely safe with permanently running self-tests         [*] Integral service interface for PC      [/list]
Height240 mm
Length 140 mm
Weight2.5 kg
Width190 mm
