Beckman Coulter - Avanti J-HC
A New Dimension in Bioprocessing.The Beckman Coulter Avanti® J Series Bioprocessing Centrifuge Systems feature performance and biocontainment capabilities unattainable with high-speed or super-speed centrifuges. Designed for efficient product recovery, new J-Lite® and J-Wide batch rotors enable high-throughput processing: 7.5 liters in 10 minutes at forces from 300 to 17,700 x g. Features include a high-torque, energy efficient SR™ drive for the fastest acceleration and deceleration possible with gentle precision. All models feature advanced programmability, automatic rotor identification and imbalance safety check, CFC-free refrigerants, FRS (Friction Reduction System) for optimum temperature control, low energy consumption, and low heat output. Beckman Coulter significantly reduces your time and effort to complete a Validation Plan for your instrument systems by offering the right combination of data management, documentation, and support services to simplify the task. The Avanti J-HC High Capacity Centrifuge provides you with a complete solution for batch bioprocessing. A maximum of 9 Liters can be spun at speeds of 5,000 rpm and 7,480 x g for greater sample throughput. This allows processing of up to 36 Liters per hour when harvesting bacteria. Enhanced operator safety is provided with disposable HarvestLine System Liners.
0Replies10 years ago | Need PM procedure for Beckman Coulter J-HC Reply |
[list] [*] Highest capacity in its class [*] Up to 9 liter capacity for high-throughput bioprocessing using the JS-5.0 swinging bucket rotor [*] Ease of harvesting samples with J-WIDE labware and disposable [*] Paperless documentation, data management, and CGMP compliance with Spintrace II network software system [*] Fastest accel and decel times with exclusive SR Drive technology [*] Low heat output and low energy consumption [/list]
Height | 34 in |
Length | 34 in |
Weight | 660 lbs |
Centrifuge Type | Low Speed |
Maximum Speed | 10000 rpm |
Width | 28 in |
[list] Set Temperature: -10° C to +40° C in 1° C increments Ambient Temperature Range: 15° C to 40° C Clearances Required: 7.6 cm (3.0 in) sides; 16.0 cm (6.25 in) rear Humidity Restrictions: < 95% (noncondensing) Rotor Chamber Diameter: 58.4 cm (23 in) [/list]
