GFMD - Silencer S2210R
Silencer S2210RGFMD Ltd manufactures the Silencer® brand name of BRUSHLESS centrifuges, which have proven to be the quietest, most reliable centrifuge on the market for more than 25 years. The Silencer® brand of centrifuge is known thoughout the clinical laboratory as The Silent Solution®. Silencer® has become the standard in the clinical laboratory marketplace.
0Replies3 years ago | Data collection I need to know what the specific refrigerant charge is and what type of refrigerant the centrifuge use. Reply |
1Reply7 years ago | User's Manual Can anyone tell me where I can access a user's manual for this unit? Thanks!!Reply |
[list] [*] Brushless DC Motor (1 H.P.) [*] Ozone-safe Refrigeration System [*] True Non-CFC Refrigeration System [*] Completely Enclosed Rotor Chamber [*] High-Strength Alloy Rotor Chamber With Drain [*] See-Through High-Strength Lid [*] Dual Safety Interlock System - To Ensure The Lid Is Closed And Locked [*] Lid Interlock Warning Light [*] Rotor Imbalance Protection [*] Imbalance Warning Light [*] RCF Display Biohazard Containment Option Is Easily Added [*] Piston Lid-Assist [*] Automatic Dynamic Braking System With "OFF" Switch [*] Audible End Of Run Indicator [*] Spill Resistant Control Panel [*] Direct Drive System [*] Microprocessor Control [*] Digital Speed Display [*] Digital Temperature Display (set point and active) [*] Digital Time Display [*] Timer Range 1-99 Plus Hold [*] Non-skid Work Surface Located To The Right Of Lid Opening [/list]
Height | 16.5 in |
Length | 21.5 in |
Orientation | Benchtop |
Maximum Speed | 4000 rpm |
Width | 31.25 in |
[list] Maximum RCF: 3,200 x g 1,328 x g Approx. Acceleration Rate: 0 - 4000 RPM: 60 seconds Approx. Deceleration Rate: 4000 - 0 RPM Brake On: 60 seconds Brake Off: 360 seconds [/list]
