GFMD - Silencer S2210
Silencer S2210GFMD Ltd manufactures the Silencer® brand name of BRUSHLESS centrifuges, which have proven to be the quietest, most reliable centrifuge on the market for more than 25 years. The Silencer® brand of centrifuge is known thoughout the clinical laboratory as The Silent Solution®. Silencer® has become the standard in the clinical laboratory marketplace.
FORUMSView All (13)
5Replies4 years ago | Help 02 EEPROM Memory Error The motor was replaced and had to be re-wired to spin counter clockwise. Now the Help 02 EEPROM Memory Error pops up. Any ideas on how to clear the error? thank you. Reply |
4Replies4 years ago | rotor removal I need assistance removing the rotor. I have removed the secure nut as stated in the manual but the rotor will not budge. Am i missing a step? Thanks Reply |
6Replies5 years ago | operations manual Does anyone know where i can find the owners/operations manual to this centrifuge? GFMD cant help because its considered obsolete. Reply |
[list] [*] Brushless DC Motor (1 H.P.) [*] Completely Enclosed Rotor Chamber [*] High-Strength Alloy Rotor Chamber With Drain [*] See-Through High-Strength Lid [*] Dual Safety Interlock System - To Ensure The Lid Is Closed And Locked [*] Lid Interlock Warning Light [*] Rotor Imbalance Protection [*] Imbalance Warning Light [*] RCF Display [*] Biohazard Containment Option Is Easily Added [*] Piston Lid-Assist Automatic Dynamic Braking System With "OFF" Switch [*] Audible End Of Run Indicator [*] Spill Resistant Control Panel [*] Direct Drive System [*] Microprocessor Control [*] Digital Speed Display [*] Digital Time Display [*] Timer Range 1-99 Plus Hold [/list]
Height | 16.5 in |
Length | 21.5 in |
Orientation | Benchtop |
Maximum Speed | 4000 rpm |
Width | 19.25 in |
[list] Maximum RCF: 3,200 x g 1,328 x g Approx. Acceleration Rate: 0 - 4000 RPM: 60 seconds Approx. Deceleration Rate: 4000 - 0 RPM Brake On: 60 seconds Brake Off: 360 seconds [/list]
