EllTec - Animec AM-4
ELLTEC AM-4 is an electrically powered dry heat warmer that supplies external heat to the L-fusion disposable warming bag.The L-fusion set is placed between the two aluminum heating plates in the AM-4.
0Replies12 years ago | Got battery back up Is AM 413 BUILT IN any battery back up WHEN POWER CUTT OFF Reply |
[list] [*] Automatic Temperature Control - Heating is controlled by one effluent temperature sensor and two heating plate temperature sensors [*] Temperature Display - Easy to read by LED display shows the temperature of the fluid. Accurate fluid temperature increments of 0.1 ºC degrees [*] Alarm - An audible buzzer and visual alarm are activated at a fluid temperature of 41.5 ºC (AM-412), 39 ºC (AM-413). The alarm buzzer volume is adjustable. [*] Quick set-up - The L-fusion set is placed directly between the heating plates. [*] Rapid warm-up - Ready to use in 2~3 minutes [*] Safe performance - Protection from over-heating, electric shock and contamination Protection from air bubbles is provided via the air chamber in the L-fusion disposable set [*] High durability - Simple construction and shock resistant. [/list]
Height | 266 mm |
Length | 78.5 mm |
Weight | 3 kg |
Width | 182 mm |
