Hettich - UNIVERSAL 320/320R
This compact benchtop centrifuge is conceived for high sample throughput as well as for high sample volumes.With a maximum capacity of 4 x 600 ml, 140 blood collection tubes or 16 microtiter plates, it is ideal for applications in clinical chemistry, biotechnology and in life science research facilities. The temperature can be set in Fahrenheit degrees. The Hettich Universal 320 Benchtop Centrifuge fits the recurring theme of Hettich: a small benchtop that has a large capacity , large feature set and low cost of ownership.
FORUMSView All (3)
0Replies6 years ago | Setting temperature How do I set the temperature for the Universal 320 R? Thank youReply |
3Replies8 years ago | Heating of centrifuge rotor We have a Hettich Universal 320 centifuge.When we use the rotor 1615 at 10000 rpm the rotor and probes heat very much. What is wrong with our centrifuge? Reply |
0Replies10 years ago | Rebooting, shows version, then after approx 8 seconds it reboots and shows verison again Starts it up, it shows version, then after approx 8 seconds it reboots and shows verison again...goes on like that until you turn it off. Has someone seen this behaviour before? Reply |
- The fully developed, up to date N control panel meets the requirements of the users and is extremely easy to operate
- Entry of the parameters is fast, precise and convenient with selector keys on the waterproof foil keypad
- The large display is easy to read. During centrifugation the actual values of the parameters are indicated
- The parameters remain in the memory even after the centrifuge has been switched off
- Noise Dampening Technology
- Push button open and close lid with drop protection
- 10 user defined settings
