Hettich - EBA 20
Hettich EBA 20 small volume sample preparation centrifugeFORUMSView All (6)
1Reply3 years ago | user guide I need to download the manufacturer's instruction for use guide for the centrifuge that is available with usReply |
3Replies4 years ago | Time and speed RPM not change Hi friends can you help me please the device is work but the time and speed not change not error appears and I search in service manual not found anything I do check for control panel not have fult in board??? Reply |
4Replies4 years ago | Troubleshooting Cause of Lid refuse to opening and what to do. What is the use of attached pin under the machineReply |
[list] [*] Quick entry keypad [*] Automatic lid locking [*] Microprocessor-controlled [*] Variable, it accommodates various tube systems as well as glass tubes without adapters; from 4-15ml tubes [*] Impulse key for quick spin [*] Speed RPM: Input in increments of 100 [*] Display of current values [*] Time: Input in minutes, max. 99 minutes, continuous run, short cycle mode [*] Display of the actual values during centrifugation [*] Smooth and QUIET running [/list]
Height | 216 mm |
Length | 292 mm |
Orientation | Tabletop |
Weight | 4 kg |
Maximum Speed | 6000 rpm |
Width | 231 mm |
Consumption: 65 VA
