Hettich - HAEMATOKRIT 210
by Hettich
At 16,060g sedimentation is completed in just a little over 6 minutes. At any rate, a run time of 10 minutes is sufficient. The rotor comes to a braked standstill. Each capillary is secured within its own chamber and supported by a holding tray. This holding tray serves to contain glass shards and any leakage should a tube break. It is easy to clean and disposable in the case of glass breakage. Capillaries, to be used for quantitative buffy coat analysis are centrifuge in the 20-place rotor prior to further analysis.
0RepliesSat Mar 17 2018 | ERROR "-F-" good day friends, someone could give me the technical service manual, since the one I found on the web and verifying the error code sent me to find information at the customer service. I thank you, thank you.Reply |
[list] [*] Quick entry keypad [*] Easy-to-read, digital display [*] Display of current parameter values. [*] Easy entry of the parameters [*] RPM in increments of 100 [*] Running time in minutes, max. 99 min. [*] Lid locking and holding [*] Emergency lid lock release [*] Motor overheating protection [*] Imbalance switch-off [*] Standstill indication [/list]
| Height | 247 mm |
| Length | 330 mm |
| Weight | 10 kg |
| Width | 275 mm |
Consumption: 300 VA
