FutureMed - Astoflo Plus
by FutureMed
Astoflo PLUS efficiently warms transfusions, infusions and medical irrigation solutions at flow rates of up to 1,300 ml/hour.
The most unique feature of this dry heat warmer is that fluids are warmed in a standard infusion set without the need for a special disposable.
  • Adjustable temperature setting from 33EC to 43EC, in 0.5EC increments
  • Digital display of the set and actual temperatures
  • Audio and visual alarms indicating low and high temperatures
  • Three independent temperature sensors
  • A circuit shut-off to eliminate the risk of overheating
  • Easy to change heating profiles available in 2 different lengths (180 cm and 240 cm), and for infusion sets with 4-5 mm and 6-7 mm diameters
  • The IV line can be removed from Astoflo Plus without interrupting the flow of fluids to the patient
  • Astoflo Plus is a waterless dry-heat warmer and can be wiped clean in seconds
  • Setup is quick and Astoflo Plus becomes ready to use in seconds
