FutureMed - Animec AM 2S
Animec is a reliable, low cost warmer that saves you even more by using your own standard tubing.A fluid warmer that uses standard IV tubing instead of special disposable sets.
0Replies2 years ago | Temperature range What is the temperature limits for this machine if i want to buy itReply |
[list] [*] Animec is easy to use. [*] It also sets up quickly - in approximately is 30 seconds. [*] Warm-up time is 4 minutes. [*] No special training is required. [*] No special warming set is needed. AnimecTM is used with standard tubing, saving you both money and time. [*] Because Animec can be kept close to the patient, heat loss is kept to a minimum. [*] Multiple safety thermostats insure that overheated fluid does not reach your patients. [*] Animec is available for use with 4 mm (Model AM-2S-4A) or 5 mm (AM-2S-5A) standard IV and infusion sets. [*] Animec is recommended for low flow rates, ranging from 60-720 cc/hr (1-12 ml/min). [*] UL approved for electrical safety. [/list]
Height | 176 mm |
Length | 36 mm |
Weight | 560 g |
Width | 65 mm |
