Gaymar - Medi Therm MTA 6900
The Medi-Therm Hyper/Hypothermia System delivers regulated heat or cold therapy with microprocessor accuracy and reliability.
Gaymar has been manufacturing hyper/hypothermia devices for non-invasive, conductive temperature therapy for 40 years. The Medi-Therm Hyper/Hypothermia System delivers regulated heat or cold therapy with microprocessor accuracy and reliability. Clinical applications include warming for perioperative normothermia, actively rewarming trauma patients and acute hypothermia victims; and for actively cooling febrile patients, and providing therapy for patients with cerebral trauma or malignant hyperthermia.
FORUMSView All (6)
1Reply5 years ago | Troubleshooting Hot solenoid is not being powered, cold solenoid and compressor still remain connected yet when temperature set point is setted 42 degree.Reply |
1Reply7 years ago | Flow out of both ends Has anyone ever experienced the water flow not cycling but flowing out of each end. Unit is in field , just trying to uncover before servicing. Thanks. Reply |
0Replies8 years ago | Monthly cleaning procedure Does anyone know for the monthly cleaning procedure if there is any alternate cleaning solutions? The MTA33 Algaecidal solution that they recommend to use is way over priced(like 400 a gallon from stryker). The manual says to not use bleach due to it causing damage to their heating element. We have other patient warming units that recommend bleach but this one doesn't for some odd reason. Reply |
SERVICE COMPANIESView All Warming/Cooling Unit Companies
- Economical choice for non-invasive, conductive temperature management
- Used with the Rapr•Round™ body wraps, or Mul•T•Blankets, the Medi-Therm system offers precise cooling and warming to maintain normothermia, manage fever and help maintain perioperative normothermia
- Automatic mode for reduced nurse intervention (includes Rapid, Moderate and Gradual settings)
- Regulated therapy with microprocessor accuracy and reliability
- Separate heating and cooling reservoirs for quick and effective therapy with continuous water flow
- Dual over-temperature systems with both visual and audible alerts to ensure caregiver and patient safety
- Interfaces with all YSI400 series disposable and reusable temperature probes and both disposable and reusable probes
Height | 37 in |
Length | 18.75 in |
Weight | 121 lbs empty, 141 lbs full |
Width | 14 in |
Flow Rate 17 gph per minute with H/H blanket or wraps
Power 120 VAC, 60Hz, 11.5 amps
Temperature Settings Manual: Water temperature selection range 4 to 42°C (39.2 to 107.6°F)
Automatic: Patient temp. selection range 30 to 41°C (86 to 105.8°F)
